Question about KitchenAid Dishwashers
Top dishes do not get clean. Have disasseembled water supplly and it is clear to upper rotating arm. it seems like a pump issue?
  • KitchenAid Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 20, 2011
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
The upper arm is not rotating
Take it apart and clean it, water pressure should spin it around, there are bits of food/rice plugging it and stoping it from rotating.
Apr 22, 2010 | Siemens SE24A230 ExtraKlasse Built-In...
Dishwasher not cleaning dishes on top rack
Check the riser tube coming from the pump assembly and be sure it isn't blocked or that something else isn't obstructing the pump intake area. Make sure the upper wah arm assembly isn't excessively loose on the spindle and losing pressure because it's leaking. You may have to remove the lower rack, lower wash arm and cover to see.
If everything is clear, it could be a worn or damaged pump impeller. If the machine drains normally, it's not the motor.
May 16, 2009 | Dishwashers
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Figidare dishwasher
It seems other posts were correct - The upper arm doesn't spin all the time. Once I learned that, and let the dishwasher cycle through, I saw that the upper arm does spin. So, there wasn't a problem with the upper arm afterall. That doesn't solve my crusty dishes problem, but that may have something to do with the soap we're using. We're going to try changing that next.
Dec 27, 2008 | Dishwashers
Upper rack dishes not coming clean.
You could try running it with the upper arm removed, just so you could be sure that the pressure is not getting to that point - unless you are absolutely sure the upper arm holes/channels are all clear then descale it overnight with some vinegar - just might clear something. if there is obviously only a little flow of water then perhaps you could try getting vinegar into the supply pipe using a basting bulb/syringe or similar - again leave overnight and you may get lucky. The next thing would be to take the machine apart so you could follow this hose through to the pump - undo it from the pump and blow through it or see if you can get a piece of wire in it from the pump end. try vinegar again. check the pump outlet for blockage. Hope this helps :)
Mar 14, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
Figidare dishwasher
Maytag MDB4000AWW dishwasher:
Neither bottom or top arms seem to be rotating during wash cycle and dishs do not come out clean!
Wayne Wheeler
Jan 24, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
Water not getting to the upper level, dishes not cleaned.
Penrod, sounds like a circulation problem. Two things to check first. make sure the upper spray arm is not clogged with debris or split. Second is to twist and remove the filter and clear out any debris where the water enters the circulation pump impeller. If something has jammed the impeller, you would have to remove the dishwasher, remove the tank, remove the circulation motor and clean out the impeller...Catriver...post back.
Sep 03, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
