Ingersoll Rand Comapctor SD - 122 Series. Problem with Vibration when compacting. 1. Request Wiring Diagram for Vibration circuit. 2. Trouble shooting Guide.Vibration problem. 3. Specification for Oil ( Drum ) Type specs. Oil. Please if you can help in these vibration problems.
harvester3
  • 181 Answers
SOURCE: dismantle guide for ze4540ca request please..
Here is an excellent site for Toshiba assembly guides. They also have guides for HP, compaq, etc. although the link will just take you to HP's repair/service site which has the service manual available as a free download. Good luck http://repair4laptop.org/disassembly_toshiba.html
Posted on Sep 04, 2007
lordoflinux
  • 31 Answers
SOURCE: How can I get the SP-1 service pack from MS to load?
Go to this link and save the file:
http://www.microsoft.com/downloads/thankyou.aspx?familyId=b0c7136d-5ebb-413b-89c9-cb3d06d12674&displayLang=en
If you can not download it from the Vista computer, try to download it from a friend's computer and save it to a thumb drive or burn it to a CD. This is for the 32-bit Vista Operating system. If you are running the 64-bit OS (don't just go by your Processor that is 64-bit, but your actual Windows Vista operating system), then go to this link for the 64-bit version:
http://www.microsoft.com/downloads/thankyou.aspx?familyId=874a414b-32b2-41cc-bd8b-d71eda5ec07c&displayLang=en
Hope this does the trick!
Posted on Mar 27, 2009
  • 7 Answers
SOURCE: Three things not mentioned 1. Specs for Ram
You need DDR SDRAM - 333.0 MHz - PC2700 (184 Pin)
The current is a CD-RW / DVD-ROM combo - Integrated, 24x (CD) / 8x (DVD-RW) / 2x (DVD-RAM) this is actually quite sufficient, most CD ROMS never burn at full speed anyway. If you really want more capabilities in my opinion it is much better to go to an external CD/DVD/BR burner, it will work faster and be a lot easier to install.
Current HHD - 40.0 GB - 4200 rpm IDE, you can go to 100 GB if you need to, get a 7200 RPM for more speed.
Posted on Jun 07, 2009
  • 5 Answers
SOURCE: how long should it take to fill up 80 gal tank
10 to 13 minutes from 0 psi to max and auto-shutoff. Tank will be extremely hot, also. Hope this helps!
Posted on Jul 15, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
Serial Number on a 231ha-2
look at the reverse button on the back of the airtool
it's on the oposite side of the dial numbers that show the
power speed.It's stars with two letters and two numbers
and a letter the picture shows it with a red arrow
Mar 31, 2014 | Ingersoll Rand 231HA-2B 1/2" Drive Ext...
Problem with Ingersoll Rand - Rand 1/2" Impact Wrench, Quiet Tool with Extended Anvil wont shutoffwont shutoff
The IR 2135-k303 air inlet repair kit along with a IR 2131-322 inlet removal tool should fix your problem.
Jun 02, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
Diagram of parts
you can download ingersoll rand tool manuals and parts lists from
www.irtechpubs.com
Jan 22, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
Need plug hook up diagram for 220 for Ingersoll Rand 2475N7.5 Type 30 2-Stage Air Compressor
Hi dcrouch537
Found these pictures on another webpage..
This should make your wiring much easier
"A picture is worth a thousand words" Please take time to rate mehunter19_46m_1.jpghunter19_46m_2.jpg
Sep 07, 2011 | Ingersoll Rand Type - 30 Reciprocating Air...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
Need wiring diagram for 'Low Oil Level Switch, part # 32276313.
trying to find diagram for you. LOLS will be wired in series with pressure switch.
Jan 26, 2011 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
