Question about Vacuums
I cannot get the feed dog on my Singer 4423 machine to raise. It is the first time I have dropped the feed dog to try sewing on a button & now it will not come back up......can anyone help please & thanks!!
SOURCE: my singer 4166 sewing machine won't pick up the bo...
I had the same problem straight out of the box. I decided to buy a new machine and came across the 4166. It had more than enough functions and seemed to run smoothly. I too have problems with the bobbin not threading so I took it back into the store thinking I was doing something wrong. The saleswoman had the same problem. I was going to exchange it for another but before leaving I wanted to check to see if it worked. Again, same problem so I left without a machine. I spoke to the owner only to be told that 30% Singer machines are lemons and have to be returned for servicing because they don't work from the start. This is a waste of money and time.
The only suggestion I can offer is to either forget about the machine or take it into be serviced.
Posted on Jun 26, 2010
deme-tri
  • 90 Answers
SOURCE: I broke the pressor foot
i could sell you a new one and explain how to install it.
Posted on Sep 20, 2010
  • 484 Answers
SOURCE: I slid the lever to
Rotating the hand wheel will not move them. The lever should slide back from whence it came. Make sure you don't have the needle down among the dogs before you try to move it. The presser foot should also be raised first.
Perhaps something has fallen down there. Try sucking with hoover as perhaps a broken needle has slipped down. Or a tiny bit of machine oil might help move them.
Posted on Dec 20, 2010
  • 223 Answers
SOURCE: My Singer Sewing machine (model
It's stuck inside. Open it up so you can see inside the bottom, look for the feed dog mechanism and you'll find where length of step is varied, this is where the reversing takes place too. Tapping gently and oiling will free it up.
lp
Posted on Dec 29, 2010
Testimonial: "Thank you so much! I was able to fix my sewing machine and save myself about $200! "
bargainbox
  • 1388 Answers
SOURCE: I have a Janome Memory
You have ended up in the Vacuum cleaner section, but if you look in your User Manual on page 71 you will be able to read about how this is achieved...feeddog switch, then rotate hanwheel one full revolution to re-engage.
Cheers Bargain Box
Posted on Apr 08, 2011
HOW TO INSTALL NEEDLE PLATE ON SINGER 30518 SEWING MACHINE?
Hey, i just took the needle plate out to clean and i cant put it back. same model 30518, somebody can help? :(
Oct 27, 2014 | SewShop.com Singer Model 30518 Instruction...
My machine flashes C4 when i want to sew
Clean the bobbin case area thoroughly, and probably the feed dogs, too. Start all seams by holding the top and bobbin thread ends together behind the presser foot for the first few stitches. If you have lost your manual, pick up a new one, free, at http://www.singerco.com
Mar 21, 2014 | Singer 7256 Fashion Mate Sewing Machine
Feed dogs where is switch
You should post this in the sewing machine section. It is posted in the vacuum section
Jan 25, 2014 | SewShop.com Singer Model 6233 Instruction...
Machine is stuck on reverse mode
Try this,Go back to straight stitch, zero your stitch length,zero your stitch width, turn your hand wheel towards you for few rounds then select a stitch length and see if the reverse lever will work normal after this. Otherwise get it fix by a local technician.
Nov 08, 2013 | Singer 4423 Electric Sewing Machine
Feed dogs don't work!
Many of the older machines had a long geared belt that operated the feed dogs. Turn the machine upside down, take the bottom off and check. If there's a belt there, check it for tautness and for useability. If there is a belt, take it off and try the sewing machine repair shops in Kazoo on S. Westnedge for a replacement.
Oct 23, 2013 | Singer CG590 RBFree$30CarVac*18Stitch...
Cannot raise feed dog
not sure why this is in Vacuums... but if you know where the switch is... jiggle the handwheel while moving the switch. This will help the dogs return to feed setting.
Mar 19, 2013 | SewShop.com Singer Model 717 School Model...
Singer Stylist 7258 will only sew backwards and is only making holes...no stitches!
this link is for the manual go to page 32 ,it sounds like you have it on button hole stitch witch goes in revers, you need to press button hole off switch.
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Oct 23, 2012 | Singer Stylist 7258 Electric Sewing...
My Singer Sewing machine (model 6215) is now only sewing in reverse. After pressing the backstitch button, the button seemed to stick in the backstitch position. I was finally able to pull the button out...
lp
Dec 29, 2010 | Vacuums
I slid the lever to lower the feed dogs and now (like so many other people have posted on the internet) I can't get them back up! I've sought out answers on the Singer website have called/emailed them but...
Dec 20, 2010 | Vacuums
Vacuums Logo
134 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
