Question about Philips 50PL9126D/37B 50" DLP TV
MY PHILLIPS TV POWER BUTTON IS FLASHING 6 TIMES SLOW THEN 5 TIME FAST, BULB WAS REPLACED
  • 35 Answers
SOURCE: my DLP tv will not turn on the power button flashs
have you changed the lamp? J.D.W.
Posted on Jun 18, 2009
SOURCE: I have a Phillips 50pl9126d/37
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Posted on May 17, 2010
  • 608 Answers
SOURCE: I have a Phillips dlp
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps kits can be bought online ,are inexpensive and, if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 14, 2010
toyladi3
  • 597 Answers
SOURCE: My Philips tv 60PL9200-37 has
When your television actually flashes the front blue light, it is passing a message that there is a problem inside the unit. There are 2 things you should check but my best bet is that it is the t-con board of the television that is bad. The other component you can check is the lamp, but if the lamp is faulty you will not be getting sound therefore the problem is from the t-con board.
It is located by the middle of the main panel of the television, once you get it replaced, the television will be in good shape.
Take care and good luck
Posted on Jan 02, 2011
SuperTech-11
  • 1591 Answers
SOURCE: my tv flashes 6 fast
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Jul 20, 2011
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
How to replace the bulb in PHilips tv model 60PL9200D/37 ?
my tv flashes 6 times slow,pause,5 times fast but it dont power on
Sep 23, 2010 | Philips 60PL9200D Projection Televisions
I have a Phillips 50pl9126d/37 it wont turn on picture or sound blue light in the front flashes 6 times fast looked at the bulb and it doesnt seem broken ie( no glass bits inside broken off) otherwise...
Dec 11, 2009 | Philips 50PL9126D/37B 50" DLP TV
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Issue with my philips dlp
I now have the same issue. Did you ever solve your problem? Did you find the ballast ? Where ?
Jan 07, 2009 | Philips 60PL9200D Projection Televisions
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Philips 50PL9126D/37B 50" DLP TV Logo
303 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
