Yamaha Grizzly 660 2002 2008
get one of these..If you are going to try the repair yourself....
.this is serious, ....
there MIGHT be damaged components that need to be inspected by a professional.
SOURCE: replacing rear axle dust cover boot on 2005 yamaha
Inner or outter?? The outter cv joint doesn't come apart. If you rip the outter boot, you need to get a new half shaft. The inner cv joint has a clip inside that you have to take out to split the joint and install a new boot. You also need boot clamp pliers to tighten the clamps or it will come back off first time you ride it.
SOURCE: 2008 Yamaha 660 Grizzly???? Help?
try turning your idle down, i have a 98 grizzly 600 and the other day it was cold so i turned the idle up to start it and wen i put it into gear i would drive itself if ur idle screw is in the same place as mine it should be above the engine beside ur left leg turn it left to turn it down wen ur idle is up ur motor is reved to hi wen going into gear hope my advice helps
SOURCE: 2008 450 kodiak atv
check the oil level in the differential. If run a long time low on oil it may have damaged gears and bearings. Look for leaks past seals and cover gasket.
SOURCE: when i start the atv with the choke it stays on ,
The choke should only be used when starting cold. After the bike is warmed up you can turn the choke off. If it keeps shutting off after being warmed up for a few minutes, then check your gas/air ratio for the idle air mixture knob. Loosen it up 1/4 turn to allow more gas to flow.
