Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
KUDPO2CRBLO dish washer starts but doesnt finish cycle
  • KitchenAid Master
  • 43,501 Answers
The timer/control board has gone bad and will need to be replaced...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
If washer doesnt spin the clothes enough-what button do i push for the spin cycle?
Pull out your timer dial and turn it to where the line is pointing at the beginning of spin cycle
push in
it will start to sip and finish the cycle with no further assistance from you
Hope this help[s mike
Feb 28, 2016 | Whirlpool WTW6400SW Cabrio Washer
Tip
We had an ongoing battle with white film on glasses and dishes, inside...
<p>If your <b>dishwasher does not seem to be cleaning well</b> anymore and you are getting<b> residue and film left on your dishes</b> then you need to read this.<br /> <p><br /> <br /> <p>Since July of 2010 the US Government has mandated that <b>dishwasher detergents</b> contain no more then 0.05% phosphates in them. The Detergents before this had contained up to 8.7% phosphates. The restrictions were for 16 states but many companies then dropped the phosphates from detergents to all states...<br /> <p><br /> <br /> <p>Now if you are having the <b>scum, film, and white residue problems</b> in your <b>dishwasher, </b>there is hope.<br /> <p><span>There is a product that you can buy that will compensate for what the makers of the </span><b>dishwasher detergents</b><span> have left out. This product as commonly know as </span><b>TSP</b><span> or </span>(<b>Trisodium Phosphate</b>).<br /> <p>By adding this to your dishwasher, you can manually add back the phosphates to your dishwasher and enhance the cleaning process.<br /> <p><br /> <br /> <p>Now the nest question...how much TSP do I add to the dishwasher?<br /> <p><br /> <br /> <p>For many dishwashers, waters, and for normal loads you will find that a tablespoon or two is all that you will need. For very hard to clean dishes and for some types of water you may need to add up to a 1/3 cup of TSP. <br /> <p><br /> <br /> <p>If you are having problems with your <b>dishes not getting clean</b>, a <b>black or scum film</b>, or <b>white residue</b> being left on your dishes at the end of the cycle, then I would start with a tablespoon or two and then adjust from there. Figure out how much you need to add to you dishwasher to make your <b>dishwasher detergent </b>work correctly for you again.<br /> <p><br /> <br /> <p>To best part is that you can have <b>clean dishes </b>coming from your dishwasher again!!<br /> <p><br /> <br />
on Mar 31, 2011 | Dishwashers
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
I have a 501 ht moyer diebel undercounter dish washer that doesnt drain all the way
Could be a clogged drain line, a failing pump or even the dishwasher not level
Jan 16, 2013 | Dishwashers
The cycle has finished and the dry light is on and it keeps beeping. Usually it beeps 8 times then all lights go off and cycle is finished. i ahev just filled it with salt but this has never happened...
ok why whoud you put salt in dish washer you screwed it up from doing that the salt sweld up and cloged the sencer the sencer is your intake and your intake takes water in out clean out with dish soap 1 or twice with mild water mixed with dish soap[
Feb 15, 2011 | Dishwashers
Soap does not all desolve during wash cycle, there is always some left in the door. we use cascade. this dish washer is new and we have always had this problem.
this could be caused by hard water depending on where you live. Make sure you always use Jet Dry, run the hot water on your kitchen faucet for a few minutes before you start the dishwasher and if that doesnt work there are a few different dishwasher cleaning products out there. This one works good: http://www.finishdishwashing.com/product-finish-jet-dry-dishwasher-cleaner.php.
Nov 10, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
57 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
