Question about Haier HLC22R1 LCD TV
I'm trying to set up my Haier TV as a monitor for my PC. When I disconnect my old monitor and then connect the TV everything works fine. When I restart the computer the windows start up shows and then the TV goes black and gives me a "No Signal" response. **I've tried changing the resolution and also tried installing PowerStick to create a custom setting for the TV. However, nothing seems to stick after the restart.
    Top Expert:
  • Haier Master
  • 78,010 Answers
Sorry but that is not a thing that is adjustable.
Posted on Jul 07, 2017
2 Suggested Answers
  • 4 Answers
SOURCE: I connected my laptop to my LCD TV using VGA
Easy way:
Press and hold Fn key, and then look at the F1-F10 keys.. Most likely it is F7, and has a picture like a computer screen.
So, press and hold Fn key, and then press F7 (or whatever key it is for your laptop). This will change your "presentation" settings, and thus switch back and forth from laptop screen, laptop screen + external screen (TV), just external screen (TV).
If this doesn't work as you expect, just try:
Instructions for Windows XP:
Open the Display Properties window by:
Start -> Run -> %windir%\system32\control.exe desk.cpl,@0,3
(this is the same window where you can change screen resolution).
There you will see two or more "screens", labeled: 1, 2, 3.
Click on "1", and you'll see:
[X] Use this device as the primary monitor
[X[ Extent Windows desktop onto this monitor
Click on "2", this is your TV.. Mark
[X] Extent Windows desktop onto this monitor
Then change the resolution to 800x600.
Click Apply
=> now your TV should start showing you a picture.
You can move your mouse between the laptop screen and the TV screen.
If you want just the TV, you can make "2" to be your primary monitor, by clicking on [X] Use this device as the primary monitor.
Posted on Nov 04, 2009
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
Dec 15, 2012 | Haier Televison & Video
Haier L24B1180 24
Most new can now a days. In any case, took a quick look at your specs and simply connect to PC. Then choose input from TV. Like VGA, HDMI, depending on cable paring you choose for your PC video card. VGA is usually the easiest.
Aug 29, 2012 | Haier L24B1180 24 inches 1080p LCD 24 LCD...
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
How to I connect my Haier tv to my pc and have it act as my monitor?
If you have a standard video card on you p.c, that is with the 15 pins vga connector, all you need is a standard vga cable .Connect it in the pc in at the back of your monitor and turn the monitor on, with no other input connected to the set it should autodetect the pc.for the sound you`ll need a 1/8" phone jacks stereo cable connected to your sound card. have fun
Nov 03, 2009 | Haier HLC22R1 LCD TV
Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Aug 21, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor black with green light on
did you changed frequency of that monitor? if it is out of factory setting that could be the problem, try to connect it again as secondary and set Hz to default, if that does n't work try same settings on both monitors? i have connected two monitors i had same problems , my secondary monitor was clone for tv if you are using secondary monitor for clone to ty (with s-video or whateever) if tv is old it must be 60HZ 800x600...
Apr 27, 2009 | Computers & Internet
Sounds like the PC has too high a screen resolution set for the TV to handle
Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings.
connect PC to TV, TV should be able to display PC data now.
Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution.
If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Hope this helps.
Dec 19, 2008 | Computers & Internet
Monitor issue
there are loads of ways to do it up the 18006249896 and the dell tech support with be able to help out
Oct 28, 2008 | Dell Dimension 2400 PC Desktop
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Haier HLC22R1 LCD TV Logo
115 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
