Question about Kitchen Ranges
Microwave makes weird noise sounds like fan is not on but food still heats
  • 5,568 Answers
If the fan is no longer running, the noises are probably caused by components overheating.
You might try opening the unit to see if the fan blades are visible. If they are, with the plug pulled of course, push on a fan blade to see if the shaft is binding. If it is, and you can see the front and rear of the shaft, you might try spraying those points with WD-40 or similar. The sleeve bearings in cheap fans can build up particles and jam the shaft which can sometimes be freed with penetrating lubricant. If it still isn't free or cannot be accessed, you may be able to buy a compatible fan at an electrical supply house.
Posted on Mar 17, 2011
Ge microwave fan runs when door is closed and light still on
There are one or two door switches that are probably defective, that must be replaced.
May 08, 2012 | GE Microwave Ovens
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Thanks,
micro
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Jan 31, 2009 | GE JVM1860 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Kenmore 721.80523
Is there any burning smell after you try to heat with the microwave?
In most cases of no heat with a loud noise, it's a bad high voltage diode or magnetron.
Posting that video may help if you get the sound clearly.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 28, 2008 | Kenmore 62643 Microwave Oven
Microwave was working now making funny noise and not heating food and this is a brand new microwave and because i live in the virgin islands they are telling me the warranty cant be covered but the virgin...
I am having the exact same problem. There was a large POP and now it makes a weird noise and doesn't heat. Everything else appears to work though. I think it may be the HV Capacitor. Before I tear this thing off the wall and check the Capacitor does this sound like it may be the problem?
Jan 08, 2008 | Frigidaire PLMV169DC Microwave Oven
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
