Question about HP Officejet Pro L7680 All-In-One Printer
My printer is saying Memory card Error, I dont have any memory cards in any of the slots...Please help, wont print anything, I have tried to un-plug and it doesnt change anything.
  • 2,574 Answers
Usually it's the formatter on-board memory that is bad.
If a card has been used before, it may have bent a contact, or if pushed too hard, damaged the socket.
Posted on Mar 17, 2011
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
Motorola w490 (t-mobile) wont detect any memory card
The contacts in the phone are possibly dirty. To fix this, turn off the phone, remove the battery and clean it as follows:
Take a piece of thick paper (card stock is good). Cut a strip the width of your memory card about 4 inches long. Fold the strip in half and dip the folded end into isopropyl alcohol. Gently insert the damp card into the memory card slot (memory card removed) and with an in and out motion, clean the contacts by rubbing them with the card. Allow the slot to dry out for several minutes. Reinsert the battery and the memory card and then power up the phone. If this does not fix the issue, you may have to have the port replaced by a service shop.
Mar 07, 2010 | RIM BlackBerry Pearl 8100
Printer wont read SD cards does read sony memory
If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Printer says: media error, please reinsert
The most likely problem is that the Printer cannot read SDHC cards. Most cards over 2 Gig are called SDHC you can see on the card if it is infact one of those cards. if this is the case then just plug your camera into the computer and transfer the files that way then you can print them.
Jul 22, 2009 | Brother MFC 420CN All-In-One InkJet...
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
My Printer has an Error Message saying "card slot not Initialized
Try this.
1. Turn the printer on.
2. When the memory count start Press and Hold the "Menu" button.
3. Release the "Menu" button when all 3 LEDs are illuminated.
4. Press the 'back' button.
5. The display will then show "Initialize disks".
6. Press the green "Check" button to start the process. This will take some time.
7. The printer will automatically come back to "Ready" after this procedure.
If the above doesn't work, you may have a bad memory card.
Jan 22, 2009 | HP LaserJet 4650 Color Printer Manual...
Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Aug 21, 2008 | HP Photosmart C6280 Printer
HP Officejet Pro L7680 All-In-One Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
