Problem with ip address also limited activity
How about in wireless
Posted on Mar 27, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Check the cable connectivity and set your ip manually.
Posted on Aug 03, 2008
    Novelist:
  • 202 Answers
Please right click on my network places go to properties u will find a network connection i.e, local area connection right click on it go to properties there u can see two check boxes remove the lower one i.e,Notify me when this connection has limited or no connectivity and i f any problem in ip address go to Internet Protocol TCP/IP option select it and go to properties then u can change ip address, subnet mask,gateway and DNS server addresses if u know these parameters properly change and say ok apply ok it will restart the machine thats it
Posted on Aug 02, 2008
Download nic
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Aug 31, 2012 | Dell OptiPlex GX150 PC Desktop
It does not make much sense. But it seems the WAP610N has a limit on concurrent connections. We just started to use this device in a small office network. There are about 15 laptops on wireless...
Two possibilities:
1. the router is configured to hand-out IP-addresses in a limited range, e.g., 192.168.1.100 to 192.168.1.110, namely 11 different IP-addresses. When the 12th computer asks for an IP-address, there is none available. Remedy: configure the router to use a larger range of IP-addresses.
2. when an IP-address is handed-out, attached is a 'TTL' ("time to live") value, indicating how long the IP-address remains valid, e.g., 10 minutes or 100 minutes or 1 day or 1 week. If the TTL is too large, then each computer "hogs" the IP-address (even after being shut-off in mid-afternoon).
Remedy: configure the router to use a shorter TTL. Don't worry: when a TTL value drops to 50% of its original value, on a specific computer, the computer will "renew" the lease.
Mar 18, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
It shows limited connectivity.conneced but no internet.i diagnoused and it saysnot getting valid ip.once i got connected and it worked for few second and stopped and showing limited connectivty.after...
When your network shows limited connection, it could be that you system did not pick IP address from your DHCP server. so it assigned itself a public IP address. In this case make sure your system has the correct networking setting and it can reach the DHCP Server. If you are using a modem, the service from your service provider may be poor in your area.
May 18, 2010 | Computers & Internet
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like 192.168.0.xxx. If you have an IP address like 169.254.xxx.xxx you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Limited or no connectivity , can not renew IP address
the IP address must be incorrect..open control panel>>network connection>>select your connection>>check its properties>>then click on networking tab>>open internet protocols>>then select 'obtain
OR
set up a new connection
if the problem presist you need to fromat your windows drive
May 05, 2009 | Arris SURFboard SB4200 Modem
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I have a Lenovo Ideapad S10 and it will not connect with the desktop PC. It keeps telling me I have limited or no connectivity. It also tells me the network did not assign a network address to the...
It needs an IP address. A router hands out IP addresses using DHCP in most default settings. Your computer has to be set to "Obtain an IP address automatically: and "Obtain DNS server address automatically" in (TCP/IP) Properties of LAN Properties for your Device name. You can also use hardcoded IP addresses. It's pretty complicated.
Dec 26, 2008 | Computers & Internet
I am trying to connect a second laptop to my netgear router but I can only get limited or no connection?
Hi and welcome to FixYa,
Initially, let's try a quick fix:
  • determine and copy the details of the Networking of any of the other computers that can connect without a problem including the IP Address, Subnet Mask, Default Gateway and DNS servers;
  • open the Network properties of the LAN card or the WiFi card on the second laptop that has limited or no connection;
  • highlight Internet Protocol (TCP/IP);
  • click on the Properties button;
  • tick "Use the following IP Address"
  • enter the copied details (numbers) from the other computer;
  • the only difference would be that the new IP address should be slightly different;
  • example if the copied IP address is 192.168.0.11, pls make the new IP address 192.168.0.110;
  • all others stay the same.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | Computers & Internet
Unable to get a connection limited or no connectivity
hi
if u have lan problem u required your proper ip address .
also if your system ip address or computer name are same in other system in lan u got this problem.
so change your ip address and system name .
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
