Question about Mad Catz ThumbPad for PlayStation 3
I have a thumbpad 8829 do u need a charger to charge t`his
When I plug in the charger it wont charge Im not getting like unauthorized charger message it just wont charge
I advice you try get a similar charger to charge your phone, if the similar charges your phone, it means your charger is bad and will need to get another charger or the phone.
But if it did not charge and you still get the same message, it means the charging port on your phone is the problem, the charging port on your phone is bad and can not read the charger, so you will need to replace or change the charging port on your phone. Doing thi will solve the problem on your phone.
Take care.
Jul 19, 2010 | Motorola Mobility Hint QA30 Cell Phone
Hi I have N95 and when i plug charger in it says not charging can anyone help
Please check the charger by plugin with some other nokia handset and check if the charger is working fine. If still it shpws not charging with other handset then change the charger as charger is not working
Jun 01, 2010 | Nokia N95 Cellular Phone
Trying to charge my sony ericsson k800 mobile and it won't charge. Cannot get 'optimised charging' to appear. Battery now completely flat
Hi, you will need to get another charger. Charger might be faulty and will need to be replaced.
If after replacing charger and still does not charge, then the charging port where you plug in the charger is damaged and needs to be replaced.
Take care.
May 20, 2010 | Cell Phones
Motorola L9 no cherging
I suggest you try to use another charger to use another charger to charge your phone, if it does not charge, it means the charging port is bad and will need to be replaced.
You can also use your charger to charge a similar phone to see if your charger is not the problem, if your charger charges the similar phone, it means the charging port of your phone is bad and will need to be replaced.
Replace the charging port and your phone will charge.
Take care.
Apr 23, 2010 | Motorola Mobility SLVR L7 Cellular Phone
The charger slot on the phone does not work when plugged in, think it needs a new port
Why don't you use the charger to charge a similar phone or use a similar charger aside yours to charge your phone to see if it is the charger or the charging port.
If your charger charges a similar phone as yours, it means the charging port of your phone is bad.
But if it does not, the charger is the problem.
If it is the charging port, all you need to do is to replace the charging port and your phone will charge.
Take care.
Apr 21, 2010 | Samsung Instinct Cell Phone
Why doesn't my htc phone charge while plug in?
First, you need to check to see if the problem is with the phone - the battery - or the charger.
If you have a car charger, try to charge the phone with it. If it works, you'll need to replace your home charger.
If the car charger doesn't charge the phone - you'll either need to replace the phones battery or your home charger. (Sometimes the battery will go bad if you use a car charger not made specifically for the phone.)
If you replace your battery and it still doesn't charge you'll need to replace your home charger.
If after you've replaced the battery and the home charger and it still doesn't charge - your problem is with the phone and it will either need to be replaced or repaired.
Apr 07, 2010 | HTC FUZE Smartphone
My touch screen is not right. If you use the stylus and touch the center, it will say you touched about a centimeter away from where you really did.
You need to recalibrate it. You can do that by taking out all games and booting it. Use your thumbpad to navigate to the calibrate option since the screen/stylus the problem.
Nov 01, 2009 | Nintendo DS Console
Mad Catz ThumbPad for PlayStation 3 Logo
50 people viewed this question
Top Mad Catz Video Game Consoles & Games Experts
William Wurtinger
John mullen
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
