Question about JBL Media 200 Computer Speakers
NEED A POWER SUPPLY - JBL Media 200 Computer Speakers
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 17, 2011
Power supply
Any 450 Watt SMPS power supply is ok. Zebronic or Mercury retails around Rs.450 to 500. No need of costlier power supply like Corsair etc.
May 05, 2013 | MSI Custom 845 Ultra-c Ver:1 Motherboard...
Will not start
smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell Vostro 420 Desktop Computer
Dell ATX(12v) power supply
The fact that it is made by Dell is irrelivent.
ATX is a standard and so are 20 and 24 pin motheroboard connectors.
You should find what you need by searching for: power supply unit on Wikipedia and Google.
Apr 08, 2010 | Dell 200W ATX Power Supply GX1 - GX110...
Need a part number for a 3310Le 110 vac power supply
Oops!
Generally the unit should have a part number attached to or printed on it somewhere. This is for the board with the power switch attached, it's called the power supply unit, so hopefully this is what you are looking for.
There seems to be two possible options, so you will need to determine which is the correct unit you need.
AZ23 0204 - Power Supply Unit: 100V (RoHs)
H555 5010 - Power Supply Unit - 120V
Nov 12, 2009 | Ricoh 3310LE Copier
I get no power at all to my computor. There is
The easiest and safest way is to purchase a power supply tester. Just unplug the power supply wireing harness from the motherboard and plug it into the tester. It gives led readouts. Its around five dollars. or just simply take it to a computer shop, most will check that for free
Aug 31, 2009 | Antec SP-400 400-Watt Power Supply
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
Need to get a new power supply for my samsung monitor
you first look the watt on the power supply and if same watt power supply is available then connect because power supply has overload protection it will not work also look the connecter is matching if not then purchase only original power supply dont chase the duplicate it will consume more money
Nov 20, 2008 | Computers & Internet
CYBERHOME DVD RECORDER DVR1600 - Need Power Supply
Bill,
I can rebuild your power supply if it is not in aches. A Compute power supply works with these unit if you know how to modify it.
May 22, 2008 | Cyberhome DVD Recorder - DVR1600
JBL Media 200 Computer Speakers Logo
83 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
