Question about GE Profile 20.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezers - Stainless-Steel
I have had fours Sears repairmen at my home trying to find put why the light doesn't come on when door is opened. Replaced LED light assembly, transformer, tested door switches. They have no idea. One year old.
    Sergeant:
    Novelist:
  • 185 Answers
Have they checked the wiring to see if they have the correct voltage to the light. You could have a broken wire between the switch and the lite or power source......or it may not be it the power side you could have an open neutral wire which is alot harder to trace.....
Posted on Mar 17, 2011
  • m_miranda Mar 17, 2011
    i get the distinct impression they don't know what the proper voltage is. Their schematic diagrams are incomplete and they are calling in for instructions. I will ask these questions Saturday on their scheduled visit and fire them if they can not resolve the problem. $2,600 fridge one year old and they have charged me $720 for repairs that did not work. I am contesting this and not pleased with GE support either.
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
The does not completely close and one light is green and one yellow i see no disruption. then it opens up again what can i do?
Color of lights doesn't matter. If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are not flickering ever so slightly. Tweak them a little. On the rear of the motor unit there is a small LED. Check to see if it is flashing a code. It will flash a number of times, pause and then repeat. Near where that LED Is you will find the down force adjustment. Increase it about 1/4 turn and try. If the LED is flashing code 5 you most likely have a bad RPM sensor board which is a small printed circuit board just in front of the motor.
May 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
WHEN TRYING TO SELF CLEAN OUR KENMORE ELECTRIC RANGE WE GET THE E1-F5 LIGHT?
The E1 - F5 error code indicates that the oven door lock assembly is not operating. The oven will not begin the self clean cycle unless the oven door is properly locked. This failure is normally caused by a failed door lock assembly. In rare instances, it can be caused by a failed control board or a wiring failure. The normal troubleshooting for this problem is to unplug the range and check the wire harness connections between the control board and the door lock assembly. The first image below shows the access information for the components in this model of range. The second image shows the wiring diagram with the door lock circuit highlighted. If you are able to unplug the range and check the wiring connections, you can likely fix this problem yourself. If the wiring connections are okay, the next step in troubleshooting is to replace the door lock assembly (part W10107820). You can order this part from the Sears PartsDirect website. Replacing this part will likely fix your problem. If you replace the door lock assembly and still have the same problem then the electronic oven control board may also need to be replaced. If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Nov 23, 2010 | Microwave Ovens
Garage door will not close, moves 2 ft & returns
Make sure you put the black cup back onthe end of the motor shaft and that it is pressed all the way on.Make sure the RPM sensor is plugged in. If neither of these are theissue, then you probably did not have the motor shaft pushed all theway back when you tightened the coupler after replacing the wormgear. Loosen that coupler up and from the front of the motor(opposite end in which the coupler is on) push the shaft back as faras it will go. Hold it there while you tighten the coupler back upand then try it.
Nov 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote not working
you will need to train (link) the remote to the garage door opener. to do this you will need to find the remote "train" button on the operator.
If you have the manual for the garge door opener this will show you where it is located.
push the train button on the operator, an LED light will start blinking. Then push one of the buttons on the remote. the LED light on the operator will stay on. push the button on the remote again and the light on the operator will turn off.
try the remote it should work now.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
I want to re-program my keyless garage door.
Mulleta,
If you look on the back or side of the garage door opener you will see a small square red/orange button.
Push the button one time, and you will see an amber LED come on. Go to your keypad enter a four digit (of your choice) then press and hold the the enter button until the garage door opener light flashes and you hear a clicking sound. You can release the enter button and it will be reprogramed.
Apr 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 sears door opener the remote not workinng we re set the coadswill not open door
FIRST CHECK TO SEE IF THE LOCK/VACATION BUTTON ON THE WALL CONTROL HAS BEEN ACTIVATED. THE LED ON THE WALL CONTROL WILL BE FLASHING. - SIMPLE SOLUTION PUSH THE LOCK BUTTON AND HOLD FOR 2 SECONDS TO TURN OFF LOCK FUNCTION.
SECOND TRY TO REPROGRAM THE REMOTES TO THE UNIT - THEY WILL SOMETIMES LOSE MEMORY IN AN ELECTRICAL STORM.
IF REPROGRAMMING DOESN’T HELP TRY REPLACING THE BATTERIES IN THE REMOTES AND THEN REPROGRAM.
HOPE THIS HELPS
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad for chamberlin garage door opener stopped working
You need to reprogram the keypad. Press and release the learn button on the back of the motor. Within 20 seconds, press your four digit code into the keypad and press and hold the enter button until the lightbulb on the motor blinks once. You are finished.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Nov 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
GE Profile 20.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezers - Stainless-Steel Logo
44 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
