Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
I have a GE Profile Arctica refrigerator that I purchased used last week. Developing quite a bit of frost buildup inside the upper half of the freezer. Also noticing that the flap for the ice doesn't close. Is that the problem?
    Scholar:
  • 116 Answers
Hi yes the flap will cause the frost, you need to replace the solenoid that controls that flap, if this is a side by side, the solenoid is behind the dispenser controls on the freezer door, you take off the control board, and then remove the little mount behind that it has 4 screws and you will see solenoid on right side, it needs to be replaced.
Sean
Posted on Mar 28, 2011
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Tip
Appliance Repair Meridian - GE Profile Refrigerator not cooling
If your refrigerator is not getting cold but your freezer is freezing fine there's a good chance the evaporator is frosted up or the evaporator fan isn't working. Pull the back panel from the inside of the freezer and examine the evap coils for heavy frost buildup. If that's the case, there's a heater assembly screwed on at the bottom of the evaporator. Unscrew and ohm it out. This go bad quite regularly for me and can save you money by doing it yourself.
Refrigerator Repair Meridian
on Oct 12, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
I have a GE TBX 22Z - just recently, the refrigerator half has almost stopped working. The freezer half works fine - everything stays very cold. The bottom half, however, gets quite warm and has even had...
Push gently on the back wall of your freezer. If you hear a crunching sound resembling snow under foot or dry leaves being stepped on, you have a frost buildup. Your fan may still be working, but your entire refrigerator depends on that fan being able to draw air over those blocked and frosted up coils. The most common cause of this is a dead defrost thermostat. The second and third problems are the defrost timer or defrost heater. Spin your defrost timer (located near your Temperature control, it's in a small hole with no screw in it) till it clicks and check the freezer wall to see if the frost starts to steam and melt. If not, unplug the fridge2_bing.gif, then try disconnecting the defrost thermostat (usually clipped onto the main freezer coil at the top) and join those 2 wires together. Replug and see if the heater starts steaming. If it doesn't it is most likely the timer. The heater is usually the last thing to die, unless your heaters2_bing.gif are encased in glass. In which case a quick visual inspection for decay and separation will pinpoint the problem.
Mar 13, 2010 | GE Profile 21.6 cu. ft. Top Freezer...
Ge Profile Arctica Fridge--Can I salvage it, or do I run away?
It will be worth the repairs that come up. Don't replace board till it quits and you will know when it does. The new upgraded boards are much better now with extra protection for the relays.
Jan 28, 2010 | GE Profile PSI23SGR Arctica¿...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Weekly my top freezer warms to about 40 then returns to 0 About once a week the freezer on my GE Profile Arctica PTS25LHP top freezer refrigerator warms to about 40 degrees or so then cools back down to...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Mar 14, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
179 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
