Question about Kenmore HE2 Plus Front Load Washer
I am getting a f-35 code on the washer ..what does that mean?
  • Kenmore Master
  • 8,220 Answers
F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the air trap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
Item 20
$86
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 17, 2011
Engine codes for a 1998 plymouth voyager
okay, 1998 voyager these are not obd2 codes, these are genric codes, you used ignition to get these .
these codes are for older models that use codes like these 12 35.
the newwer obd 2 use codes like po 013. i will try to see what i can find, also the engine size is important.
okay here we go, the first code is 12, this code means the battery was dead or dissconnected.
the next code 35. this code means loss of prime, code # 11
means internal transmission failure.
the code 55 means gear ratio error.
these codes would tell me that you have transmission problems. this may mean internal trans failure and a rebuild or replacement transmission is needed or shift pack needs replacing. anyhow i would have a shop check this out, these van are known for transmission problems. hope this is helpful good day
Feb 03, 2013 | Plymouth Voyager Cars & Trucks
F-35 code My washing machine Whirlpool duet steam machine keeps going into the F-35 Code and stops washing.  I don't have the book.  Please, if anyone knows what this means or how to fix it, my email is...
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Sep 12, 2008 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I keep getting error codes on washer and will not continue the cycle
That code in most cases means you have a bad pressure switch. It is generally $99.00 (approx) for the cost of the part.
May 11, 2012 | Maytag Performance MHWE500V Front Load...
Sud and f 35 code
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Dec 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does F 35 mean
You could find out by removing the bottom panel on your washer and fishing out the "tech sheet". That will give you the fault codes.
Plan "B" you could retrieve the model number and check HERE to download the tech sheet that would give that Fault code. Now let me see if i can guess:d31fdad.jpegNope ain't got a clue.
Sep 22, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore frontloading washer code f-35 displayed on machine what does this mean
F35 means there is a problem with the pressure switch or the tube going from the switch to the tub.
Jun 25, 2010 | Kenmore Washing Machines
I have an ''F 35'' error code on a Whirlpool Duet Washer Model # WFW9600TW01
An F 35 error in fact means any number of things, from the drain hose being pushed too deeply into the standpipe to using the wrong soap or too much soap and the computer triggering an over-suds condition. Your best bet is to contact Whirlpool.
Dec 14, 2009 | Washing Machines
My check engine is on and the codes that I get are 35 & 55 - what do these codes mean
code 35 is a problemin the cooling fan relay it is either open or shorted code 55 means end of code output,or to say there are no more codes. Ray
Nov 09, 2009 | 1995 Dodge Intrepid
What does F 35 mean on the front load washer? it's a whirlpool duet steam
it may be a problem with the pressure switch clean it out and see if this clears the error code
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet sport F 20 code
common F20 error requiring an about $35 water valve replaced. You can get parts and manual at repairclinic.com
Oct 14, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore HE2 Plus Front Load Washer Logo
61 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
