Question about Canon PowerShot A640 Digital Camera
No flash in "P" mode
On the mode dial on top of the camera is the Auto setting, among several others. When I use this in low light, the flash works. Right above the Auto setting is a setting marked "P". I don't remember what that stands for, but I've always been able to take pictures WITHOUT flash in some lower light situations where Auto WOULD use flash. I get better pictures sometimes without the flash. But now the flash operates in BOTH Auto and "P", and I can't seem to get "P" to function without flash. What do I do?
  • Anonymous Mar 28, 2014
    Why can't I get the flash to operate? The display shows the flash isn't engaged, but I know I need to use it in a low light situation.
  • 50 Answers
In all of modes you can use "up" key to toggle between "always on", "auto"  and "off" mode for flash. (in some mode there is only auto and off.) also the flash light icon on top right of screen shows th status of flash. I hope this helps...
Posted on Nov 05, 2008
Flash on camera is not working
Hello. If you're shooting in Auto mode and you have turned off the flash, your camera will remember that setting and the flash will not fire. If you switch the dial on top of your camera to another mode and then back to auto it should clear the setting and the flash should now fire, if needed. The other thing to try is to hold down the the flash popup/mode button while, at the same time, turning the rear control dial. You can watch your top display and the flash modes should cycle through different options.
Dec 25, 2013 | Nikon D7000 Digital Camera
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    How do I disable the pop-up flash on Nikon D5000? Thanks
    As long as jog dial is set to M or manual, the flash will not pop up automatically. Be reminded though because you have to set everything manually. If you want the auto settings without the flash, set the jog dial to the icon that looks like a lightning with stop/ no sign
    Mar 02, 2011 | Nikon D5000 Body Only Digital Camera
    How to switch off the flash in Canon Power Shot A510
    in the take picture mode, press the button that has an image of the flash on it (the top of the circle) on the right, and keep pressing it until you've selected the image that shows the flash crossed out.
    Mar 27, 2010 | Canon PowerShot A510 Digital Camera
    Canon power shot s3is, picture quality is not good, we have use flash every time. otherwise images are very blurred and dull. what change i have to made to my camera. any suggestions will help full for me
    If you can are turning the flash off and on, you are no longer in the "Auto" mode. Rotate the top selector dial to select the green "Auto" position. This will enable the camera to automatically select the best aperture and shutter speed based on the available lighting. It will also decide whether it needs flash or not.
    As you gain confidence in your abilities, experiment with the other settings on the dial. May I suggest first trying the "P" program setting. This is similar to auto, but will enable you to turn off the flash during low-light level shots. Still the camera will select the best aperture and shutter speed based on the lighting. But in very low lighting, you may have to keep the camera extra steady (such as with a tripod) to minimize camera shake as the picture is taken.
    Sep 27, 2009 | Canon PowerShot S3 IS Digital Camera
    Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
    When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
    1 Menu [AUTO POP UP]
    2 Use control dial to select [ON] or [OFF].
    3 Press the Ok
    button.
    If you are in any other mode the flash will not auto pop up.
    Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
    Canon eos 400d mode dial does not select modes
    Looks like you need to take this to a camera store and have them check it over. I don't know of any setting that would cause what you describe.
    Dec 03, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
    I need to turn red eye off on my olympus e 510
    Hi - You can download the manual from the link underlined in blue below:
    olympus e 510
    See page 34:
    Select a non red eye mode.
    Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
    Aug 03, 2008 | Olympus Cameras
    Nikon D40 - The built in flash will not ppo-up in auto mode. The only time it works is the manual modes. Are there any settings I don't know about. I'm calling it defective and will return it the store.
    With the command dial set to "auto", try to take a shot in low light. The flash should pop up automatically. You can't manually pop it up with the flash button in the auto mode. If it won't pop automatically in low light, then it certainly sounds defective.
    Apr 16, 2008 | Cameras
    Error
    Here is where you can download a copy of the manual from:
    Fuji S2 Manual
    This is what the manual says about your error:
    If FEE in in top display: "CPU Nikkor lens other than G-type
    is not set to its minimum aperture. Fix: Set lens to minimum aperture."
    If FEE is in viewfinder: "Attached flash is not set at TTL
    Auto Flash in “P” mode. Fix: Set the external flash mode to TTL, or set the camera’s exposure mode to “S”, “A” or “M”."
    Are you using a flash that attaches to the camera?
    If not, then the problem is with the aperture setting. It looks like you would have to set the camera dial to M, for Manual, and use the ring on the lens to set the aperture.
    The low battery symbol looks like a battery, all black when charged, half-black as power goes down.
    This looks like a nice camera, hope I was able to help.
    Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
    Canon PowerShot A640 Digital Camera Logo
    174 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
