Question about Haier HSW02C
Haier HSW02 1.8 cf refrigerator. no matter where the dial is set, even at 1, temp is at zero and it seem to run all the time. Thermostat? Where is it and how much for part?How to test?
jumptrout51
  • 3361 Answers
SOURCE: Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
Posted on May 24, 2009
  • 547 Answers
SOURCE: Refrigerator seems to run all the time
Hey Wisper, I had a very similar problem with my Haier. Read all about it here: http://www.fixya.com/support/t180574-freezer_10_deg_fridge_50 I replaced the thermostat ($35 or so, mail ordered) but that didn't do very much. Then I replaced the Evaporator fan ($40 for an OEM part, read the details on my other page) and that did the trick. Feel free to email me if you want more details of what the job involved. I'm @gmail.com and the address is RobCuthbertson
Posted on Sep 13, 2007
fridgetech
  • 473 Answers
SOURCE: Haier HNSE05 shuts off on it's own.
Sounds like the thermostat is bad which is temp. dial.
Posted on Oct 06, 2007
aborcass
  • 2651 Answers
SOURCE: To make the temp inside the refrigerator colder?
7 will be your cldest temp
Posted on Nov 02, 2008
MNTECH
  • 1543 Answers
SOURCE: GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Posted on Feb 16, 2009
Haier HSW02C runs ALL the time
Yes your thermostat is shorted. It's just not shutting the unit off ever. A thermostat is something you can touch as a user, so no it's not that hard to get to for replacement. Also have the unit unplugged while learning how to repair your appliance.
Apr 27, 2013 | Haier Refrigerators
My subzero 550 never stops running. everything is working fine, just had freezer compressor side charged. it just seems wrong to be always running??
try to adjust your thermostat normal setting maybe you set it to maximum setting thats why the temp. cannot reach even your comp.running long hours. or maybe your ref . is over loaded try to lessen the load or your door is have leakage of cold air try to fix gasket.
Mar 04, 2011 | Sub-Zero 700TC Bottom Freezer Refrigerator
I have a older hoover refrigerator and it run all the time even with the dial set to 1 the temp inside is 35 degrees
This is quite a common problem. It sounds as though the thermostat is faulty and needs replacing.
Sep 20, 2009 | Hoover Refrigerators
My Haier compact frig runs all time, at #1 setting: freezes all
no 1 setting is close to zero degrees C the setting should be around 4 for normal every day use
call a technician to fix /replace the thermostat
if you continue to use a metal object ( screw driver , knife, fort etc ) when defrosting , you problems with the fridge will soon be over as you will puncture the evaporator section and that is not repairable so you will require a new unit
Jul 05, 2017 | Haier HSB03 Compact Refrigerator
May 24, 2009 | Kenmore Refrigerators
The refrigerator is freezing everything, even when temp is adjust
Leads me to believe the thermostat is not working. See if you can find the model number located on the bottom frame near floor behind fresh food section door and I will be able to help you better, Thanks, Sea Breeze
Mar 21, 2009 | Refrigerators
Feb 16, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Sep 19, 2007 | Haier HNSE05 Refrigerator With Ice Box
Apr 12, 2007 | Haier HRF10WNB Top Freezer Refrigerator
Refrigerators Logo
123 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
