Question about U-Line ?chelon 2175RB-00
My Uline refrigerator model 2075RB-00 went dead. Would the likely problem be the compressor or the motor? I have power to the unit. It just stopped running. Is there a parts list for this unit somewhere or do I need to open it up to get a parts number?
  • 286 Answers
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Posted on May 15, 2009
  • 286 Answers
SOURCE: uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Posted on Jul 07, 2009
  • 57 Answers
SOURCE: My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
Posted on Oct 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: I need a parts list for uline clr2060.
This one is all I have HERE
Posted on Jan 12, 2010
  • 1218 Answers
SOURCE: I have a 3 year old U-Line U 2075RB.00, under
Good day,
You should first verify the age. There should be a 5 year warranty on the compressor. In your owners manual it might refer to it as a sealed system component or compressor.
Call your selling dealer and verify that. If it is, then have a service call performed by them, or an authorized repair station they use.
Posted on Feb 12, 2010
My U-Line beverage cooler is indicating an E5 error code and the unit will not get cold. What is this telling me?
I am not familiar with this unit but in guessing but I would not assume the thermistor is bad, actually if as you say the compressor is running that is all the thermistor can do. My first guess is the condenser needs cleaning, that is the area where it gets warm. If that is clean then the possibility of a refrigerant leak is there. If not that then the compressor most likely has a bad valve in it. I would suggest contacting a refrigeration tech after everything has been cleaned and it still does not cool.
Dec 19, 2014 | ULINE U-Line 1175BEVS-00 1000 Series 24"...
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
I have a 3 year old U-Line U 2075RB.00, under the counter refrigerator. Apparently the compressor has gond bad. It just stopped working. Do I look for a repairman or just replace it?
Good day,
Feb 12, 2010 | U-Line Refrigerators
Oct 07, 2009 | U-Line ?chelon 2175RB-00
I have U-line Model #75RB-00 Refrigerator, the motor does not run and no cold air, light does work
If your motor and compressor isnt running then replace the control. If the compressor tries to run but kicks out then you need to replace the fan. You can always bypass the thermostat to check everything before you guess at it.
Oct 01, 2009 | U-Line ?chelon 2175RB-00
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
I have a uline 75bwc and the repair man said the compressor is bad. It's only 7 years old. Should I replace the compressor or is it cheaper to but an new unit?
The compressor is the heart of the unit. As long as the unit is in good shape it would be cheaper to replace the compressor. This unit is a simple unit so all the parts hold up pretty good.
May 17, 2009 | U-Line 75BWC
U-Line ?chelon 2175RB-00 Logo
387 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
