Question about DeVilbiss 2 Startingline Spray Gun Repair Rebuild Kits
How often should the filter be replaced inside the gun
  • 10,319 Answers
If not cleaned thoroughly everytime used replace it soon
Posted on Mar 17, 2011
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
Where on the unit are the inlet valve and the push button valve?
On the front of the pump unit is a large aluminum block, the valves are inside that. The inlet valve is behind the fitting for the suction tube and the push button valve is the only one on the bottom of the block.
Dec 17, 2010 | Campbell Hausfeld Airless Spray Guns &...
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
The gun part of the wond has a hold. will I need to replace the hold gun section? If so is their a replacement?
Hi, if the gun section is just leaking, then you can replace the washers inside; otherwise, its a replacement, which is not cheap unfortunately; but most guns should fit your machine.
Oct 13, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
How do I change the gun filter on Campbell hausfeld airless sprayer?
Assuming it is detached from hose, I would first unscrew the skinny end of the filter housing that goes into the gun at the gun handle. That's cause it looks fragile and allows easier access to the wrench positions where you break down the hex fitting from the filter housing. After unscrewing the hex fitting the filter cartridge should pull out easily for cleaning or replacement.
Apr 26, 2010 | Campbell Hausfeld Airless Spray Guns &...
Ineed to replace the hose on my champion cpw1750 pressure washer but how do I disconnect from the gun or do I have to replace the gun as well
If the hose is screwed into the gun then you are lucky because you only have to replace the hose, but if the hose is clamped inside of the hose then you have to replace both the hose and the gun
Aug 01, 2009 | Garden
DeVilbiss 2  Startingline Spray Gun Repair Rebuild Kits Logo
155 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
