Question about Huffy Boys Pro Thunder Bike (20")
How do I remove the training wheels? - Huffy Boys Pro Thunder Bike (20")
    New Friend:
  • 15 Answers
You will need either an adjustable wrench, a socket of the right size, or a box end wrench of the right size
(If you read through this and still don't feel like you're up for it, your local bike shop will be more than happy to do it - and it will either be really cheap or free)
The bolt you need to loosen is on the back wheel where the training wheel meets the bike. Find the right size tool for the job.
Grab the back wheel and try to wobble it side to side, then remember how much give there is so your end result gives the same feel.
You may need a second wrench to place on the nut/s between the frame and the hub to prevent this from turning, though it will probably only be needed for tightening everything after you're done.
-Start on 1 side (doesn't matter which one) and loosen the outside bolt with your wrench/socket
You will need to remove it completely to take the training wheel off of that side.
-Slide training wheel off and hand-thread the bolt back on, not tight yet.
-Do the same for the other side, both training wheels should be removed at this point.
It may help to have someone else for this next part
-Pull the back wheel as far back as it will go, don't kill yourself, but make sure the chain won't slip off because it's too lose. Make sure the wheel is aligned with the bike frame, not twisted, otherwise it will loosen on its own
-Tighten one bolt on the outside down onto the frame. This is where you might need to use a second wrench to keep the hub from rotating. Don't turn the nuts on the axle in the area inside the frame (between the frame and the wheel) as they should be tightened correctly, instead just hold them steady while you tighten the outside nut onto the frame. If that wasn't clear, you're pinching the frame between the nuts inside, which you never moved, and the nut outside the frame, which you removed to take the training wheel off.
-Repeat for the other side while still maintaining tension on the chain.
-You should be done, check to see if the wheel can wobble side to side and compare to your earlier result. If it moves too much, continue tightening outside bolts (both sides until they're good and tight)
Posted on Mar 17, 2011
How to replace rubber wheel rings on a bachmann 0-6-0 ho scale steam engine
carefully remove the drive rod from the wheel, slip traction tire on the wheel and into groove in the wheel, replace drive rod. play with your train!
Feb 03, 2014 | Bachmann Ho Scale Trains Steam Engine...
Replace rubber tires
remove screw that attaches the side rod to the drive wheel, place traction tire in groove in drive wheel, replace side rod & screw.
Feb 03, 2014 | Bachmann Ho Usra 0 6 0 Steam Locomotive...
Bachmann train
It sounds like rather than disconnecting the current the wheels are shorting the track? Does it spark a lot when the back wheels are placed on the track? If so I would suggest the insulation on the wheel axle has broken down.
Nov 16, 2013 | Crafts & Hobbies
Hello, I bought my little girl the huffy 12in disney princess bike (blue) already assembled from walmart. she tried to ride it today, but when she pedals the back wheel spins, but the training wheels and...
ONE AT A TIME, loosen the nuts securing the training wheels to the rear axle and slide each one upward a little bit so it float a little bit off the ground when the bike is vertical, then retighten the nut.
As she develops her handling and balance skills she'll need less help from the training wheel. So you can gradually raise them a bit higher as she masters balance and then she'll develop the 'lean' for turning. Ultimately, you remove them entirely.
I hope she's wearing a properly-fitted helmet.
http://www.nhtsa.gov/people/injury/pedbimot/bike/easystepsweb/index.htm
Jan 27, 2011 | Huffy 12 in. Girls Disney Princess Single...
20 inch Slumber party bicycle will not accept training wheels? Rear threaded axle is not long enough to allow for training wheels (that i cna find)
Yes you can add training wheels to this bike. The origional axle is too short, however, if you are mechanical enough, you can remove the axle and buy a longer one. I did this for my daughters bike, and for abot 5 dollars you can pick up a longer axle which will accept training wheels. But be warned, there are several bearings and you need to place them back in the correct position or the bike will not work.
Dec 27, 2010 | Dynacraft Cycling
Garage told me problem could be the drive train. What exactly is the drive train?
The drive train is what "Drives" the vehicle literally, and it consists of the engine, the transmission, the drive shaft, (if rear wheel or 4 wheel drive) and the front/rear axle. (Depending on front wheel drive, rear wheel drive, or 4 wheel drive)
It would sound like that garage is basically telling you that you need a new vehicle.
Jun 09, 2010 | Cars & Trucks
Bell brand bicycle training wheels
hello there:
the training wheels are a simple procedure you will need to take the nuts off the back wheel and place the steel spacer and put over the axle then place the training wheel over the spacer and put the nut on making sure the the training wheels are not too low or too high.... best of luck to you hope the information is helpful
May 29, 2010 | Cycling
Install training wheels
when installing the training wheels, check to see if it is put together in this order ....flat washer, training wheel, flat washer, lock washer, nut. I hope this helps. If you are missing any of these you can find them at any auto parts store, Wal-mart, or hardware store such as Lowe's or Home Depot. (Be sure to take the traing wheel and nut to make sure you have the right size)
Dec 27, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
Our playskool train will not move forward please could you advise me how to solve this - thanks dee
Had the same problem - the train at first stopped moving, but still rotated the balls, then later stopped rotating the balls at all. The music still played, though. I found the issue to be a small belt that transfers the motion from the electric motor to the gear system. The belt is tiny (think small rubber band) and lost tension, finally detaching from the system altogether. Getting to it is the difficult part... mind you that taking it apart carries a very high risk of breaking the plastic, so be prepared to scrap the whole thing and buy new.
To fix, start by removing the 7 outside screws to essentially split the train body in half. You'll have to pry off the large green wheel that's opposite the screws (right side of train) - this part carries the highest break risk. Be mindful of a spring (about 1/2 inch diameter) that may go flying - that one goes on the outside of the little inside wheel that moves the balls around.
Once the train is split in half, remove all screws you find, which will allow you to remove the mechanical sections, which includes the battery pack, electric motor, on/off switch, and gear system, including the wheel that moves the balls around. By the time this entire section is lifted off the train body, you'll see where the gears (they're a bit greasy) are attached to the motor towards the bottom of the gearbox. The gearbox itself has 3 or 4 screws to address that will reveal the entire gear system.
I had to take the lower (smaller) gears apart in order to replace the gear belt.
Replace the gear belt with a small rubber band (you'll likely need a small screwdriver to wrap it around the wheels), then re-assemble the gearbox and system. i recommend constantly running the toy with every step to make sure everything's still connected.
with a healthy rubber band/belt in place, the rest of the gear systems will fall into place with enough torque to drive both the train movement and the ball wheel.
good luck
Dec 22, 2009 | Playskool Busy Basics: Busy Ball Choo Choo
How do you install training wheels on the girls slumber party bike
Most training wheel kits come with directions in the kit. Do one side of the bike at a time. Start with the left side and when tightening the nut back up make sure the rear wheel is still centered in the fork . When you do the right side it is the same but you have to make sure the chain stays in adjustment as well as the wheel being centered. Usually you have to remove the nut on the side that you are working on. The kit should come with a little bar with a hole in it that fits over the bolt that you just removed the nut from. Make sure that the flat side faces out and the protrusions on the bar fit into the slots on the fork. Next mount the bar with the training wheels on the bike over the first bar. Put the washer supplied in the kit over that and then screw the nut back on. Pay attention to the wheel being centered and the chain being tight enough not to slip off the crank when pedalling. Make sure you get the proper size for the bicycle. There is a video here that explains it http://www.ehow.com/video_4974885_put-trining-wheels-bike.html
Jun 24, 2009 | Cycling
Huffy Boys  Pro Thunder Bike (20") Logo
200 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
