Question about Thermador Ovens
How do I remove cover to change interior light bulb ?
  • Thermador Master
  • 2,605 Answers
Welcome to FixYa.
In order to answer your question effectively, you'll need to provide a model number for your range and confirm it is indeed a Thermador oven.
There are simply too many different styles to generalize on how to simply "remove cover to change light". In fact some Thermador lens covers are square glass covers which pull off, others are round "dome" shaped which twist off and yet others are held in place via a single metal clip or fastened in placed with a metal bracket and two screws.
I'll watch for your post and be glad to assist you in solving this problem in whatever manner I can.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Mar 17, 2011
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Change light in whirlpool gold accubake system upper microwave oven
If you need to replace the bulb for the interior cabinet, you'll need to remove the two screws that holds the upper grille in place with a Philips screwdriver.
Access to these screws are from on top of the microwave.
Once you remove the grille, you should see a white plastic cover with a release tab; pop the open and you'll have access to the bulb compartment:
Watch the following youtube video- the instruction phase of removing the grille and access to the bulb compartment starts at 2:40
http://youtu.be/RQM302PShKw
Mar 04, 2015 | Whirlpool Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
It "popped" a circuit breaker
NORMALLY THERE ARE SCREWS TO REMOVE TO ACCESS A PANEL TO REMOVE THE LIGHT BULB. IF THERE ARE NOT, THEN THE EXTERIOR COVER MAY NEED TO BE REMOVED TO ACCESS THE LIGHT BULB. THIS EXTERIOR COVER HAS SCREWS.
MAKE SURE YOUR CIRCUIT BREAKER IS OFF BEFORE YOU TRY TO REPLACE THE BULB.
Feb 20, 2011 | Ovens
Interior light went out. How do I replace it? I read someone had a similar problem but the expert said to call a service rep.saying that it's beyond the expertise (safety) of owner. So, do I call a...
It is easy to replace if you are handy. There is normally a small piece of glass with clips either side or a glass cover that unscrews which can be a little hard to turn sometimes. If it is the glass cover that unscrews dont be scared to use multigrips as the glass is quite tough but try to be gentle.
Feb 08, 2011 | Ovens
Can't get the glas cover off the interior bulb
If you cannot remove cover with normal finger force, then spray with WD40, and grip cover with a pair of vice grips with a cloth wrapped around the jaws, and try turning it that way.
If it will still not come off, then your only option is to break it, and replace bulb, but make sure you can get a replacement cover first.
Please rate my solution.
Thanks.
Aug 20, 2009 | Neff U1661 Double circotherm super...
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Cannot find interior light or its switch on Miele H251 oven
so remove metal skin on the right hand side of interior....little pip holds it in place...so shove up.
then just prise glass section gently outwards....4 clips hold this in.
bulb is a PHILIPS 25W X7L
300o H.D.
Apr 01, 2009 | Ovens
Can't figure out how to change the light bulb in the oven
normally the cover just unscrews but may be difficult if not removed for a long time - large pair of grips will help
Nov 25, 2008 | Ovens
Kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Oct 23, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
230 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
