Question about Samsung LN-T3232H Television
I have samsung 32 inch lcd tv model #LN-T3232H and serail# AJD23CRPA00178K now the problem is that all it does is click like it want to come on it does the sound over and over but never turn on the stand by light just keeps blikin on and off
  • 11,361 Answers
It may have power supply problem due to bad DC power supply filter caps, or main board, backlights inverter board. It may be detecting shorted circuits so it goes into shutdown/restart mode
Please read my guide so you will know what to look for inside. See pictures of failed SAMSUNG TVs also.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Mar 17, 2011
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Samsung 32 inch LCD TV can not turn it on
you will need to replace the power supply. I can get you a part number if you will supply the full model code and version number.
Feb 06, 2014 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung lcd tv has sound but no picture
Do you have back lighting. Shine a light on the screen. If you can barely see a picture the set has no backlight but video is good. This would rule out the main board. Not shure if this set is LED backlight or flouresent tube back light. If flouresent tube check for voltages to inverter board. 24v or 15v. They are marked on the board. If voltages are there likely inverter board. or could be power brd. Check pricing on new tv.
Oct 02, 2013 | Samsung LN-T3232H Television
Ps3 wont work on my ln t3232h says not supported mode
Very easy fix guys. all you gotta do is use either your component cables or hook the ps3 up to a different TV than change you output settings from 1080 to 720p, thats the reason your not getting an image is the ps3 is set to a 1080i or 1080p output, but the tv is only capable up to 720p. good luck ^^
Jun 26, 2011 | Samsung LN-T3232H Television
I have a ln-s3238d that i got a couple years ago. Last month it started getting a line of pixels running across the top of the screen. over the last month that problem has gron to four lines on top and...
Hi andrew, its not a big problem.. Decent TV. but the pixels are DEAD. that means you have to recover them by fixing the LCD. this would cost you around £40-60 for a 32 inch TV. hope this helps!
Nov 05, 2010 | Samsung LN-S3238D 32 in. LCD HDTV
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
Voltage Stabilizer for LCD TV
Samsung 32 inch LCD TV needs a stabilizer support or not? Can any expert answer?
Feb 19, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung 32 inch remote control problem
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
Jan 10, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Height,width,&length of 42 in tv
The TV itself measures 31.5 x 23.7 x 9.9 inches (WxHxD) with included stand. You want to make sure you have at least 4 inches of clearance for airflow on top of those dimensions.
Jan 17, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN-T3232H Television Logo
266 people viewed this question
Henry  Thomas
Henry Thomas
