Question about GE CustomStyle 21.5 Cu. Ft. Side-by-Side Refrigerator - Black-on-Black
I HAVE A GE TFX22R SIDE BY SIDE W/WATER AND ICE DOESN'T SEAM TO BE GETTING COLD ENOUGH AND ICE CREAM IS VERY SOFT REMOVED A LOT OF DUST FROM UNDER AND BEHIND ANY SUGGESTIONS
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
SOURCE: ge side by side not cold enough in fridge or freezer
the fan behind the freezer panel inside
Posted on May 31, 2008
  • 37 Answers
SOURCE: Side by side Sub Zero not cold enough.
I have the same problem with the same older model, and have kept the coils clean. I've reached the clockwise limit of the freezer control. I wish the answer were that simple. I'm hoping that the oppressive heat and humidity here (Louisiana) might be a contributing factor, but that might be just a dream, and I'll have to shell out for repairs. Still cheaper than replacing it though.
Posted on Aug 09, 2008
  • 531 Answers
SOURCE: GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Posted on Apr 07, 2009
ginko
  • 19396 Answers
SOURCE: Icemaker not working, freezer not getting cold enough....
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
HAVE GE PSS26MSRSS SIDE BY SIDE THAT WILL NOT FREEZE COLD ENOUGH OR MAKE ICE
Hi , you probably need a repairman to check the freon level and test the thermostat
Jun 19, 2015 | GE Refrigerators
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
GE refrigerator / Freezer - Erratic freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 22, 2012 | GE Refrigerators
I noticed a couple weeks ago the frig side was not cold enough. Milk spoiling but butter not getting soft. Freezer side seemed to be working ok. Now Ice cream in freezer is getting soft.
How old is the fridge? Most units have a system of tubing attached to metal fins, which is located in the back of the unit. This tubing & fins must be kept clean as dust will accumelate & insulate the freon gas from turning into a liquid.. Another problem is when the motor & compressor does NOT get enough air to cool the tubing & fins. This happens when the refrigerator is located in a closet type atmosphere where the unit is too big to get any air to the rear of the unit. NO spacing on the sides or top. ALSO, the compressor might of died. In this case, if the unit is out of warranty and/or over 7-15 years old, buy another, NOT worth the repair. If still under warranty, call vendor/manufacture.
Louie Almond
Mar 27, 2011 | Refrigerators
Doesn't freeze consistently
Here is a tip that will give you the information you are looking for...
Ice Cream Maker Parts, Instruction Manuals and Recipes
http://www.fixya.com/support/r5322664-ice_cream_maker_parts_instruction
heatman101
Jul 13, 2010 | Rival 8704 4 Quart Ice Cream Maker
Ice cream in freezer of our side by side refrigerator is soft
Try cleaning the condenser coil. It will be under or on the back of your frig. Use a vacuum cleaner attachment. Good luck
Sep 08, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer and fridge not getting cold
you have a sealed system leak or possible restriction in system. need to check freon pressure. make sure compressor is running. if not ohm out start device
Jun 21, 2009 | GE GSH22JFR Side by Side Refrigerator
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Freezer seems as if it is not cold enough
Your sensor is packed in ice and giving false reading (always frozen)
You NEED to defrost. Will take 2hr
Turn off or Pull plug on freezer
Take everything out and put in cooler, brown bags, large bin or boxes to stay cold
Defrost by setting large pail of boiling water in each side bottom of freezer and closing door(s) for 1/2hr
Open freezer, empty pails in sink and use pails to hold large chunks of ice from freezer that will come out easily
Toss out ice chunks
Check sensor to be sure it is no longer packed in ice
Wipe down interior dry
close doors
plug in
wait 1/2hr
reload with stuff you want to keep
Done!
Mar 26, 2009 | Refrigerators
GE CustomStyle 21.5 Cu. Ft. Side-by-Side Refrigerator - Black-on-Black Logo
76 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
