Question about Canon Office Equipment & Supplies
My printer comes up with an error saying Document in ADF
    Scholar:
  • 32 Answers
Hey there,
Your printer is giving you an error that a paper is jammed in the automatic document feeder. You need to lift up the cover for the document feeder and see if there are any papers stuck there. If you cant find any then go and shut off your printer and turn it back on. if its still giving you that error then there is a paper stuck and you might need to take apart parts of your printer to find it. It can be even a small piece so make sure you look carefully.
Hope this helps!!
Posted on Mar 17, 2011
Document in ADF
None of these worked for me. Here is my FIX:
Open the part containing the rollers. You can see a white plastic part which stop the documents feeded into the adf. Lower this part and insert a page into the adf just a bit further than where it would have stopped from that white stopper. This forces the machine to feed the document and clears the error right away. You only have to do this once and from then mine worked fine.
Jan 25, 2012 | Canon Pixma MX410 All-In-One Printer
My printer has an error message that says document in ADF, what do i do?
Check in ADF of your printer, papper jamed probably.
ADF is in the top of your printer.
Jun 28, 2011 | Office Equipment & Supplies
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
Document jams in the ADF (Document Tray)
  1. Press <Stop/Reset>.
  2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
  6. Close the Feeder Cover.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    When rescanning the document after clearing the error, rescan it from the first page.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
  3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
  4. Open the Document Cover and pull out the document from the inner side.
  5. Close the Document Cover.
    Note: When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Document in ADF error, however there are no
I'm having the very same problem. No paper was ever stuck and the first time I tried to scan a document by laying it on the glass, not even through the feeder and it did this, and just like with you now it won't even print. Apparently this happens a Lot. I sure wish I would have seen these issues before I bought it! I wish I could help you out, but at least you know you're not alone.
May 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
After switch on the toshiba e-studio coming uo
please do the following..
  • Open the ADF cover.
  • If shipping tape is present on the blue document feed-guide assembly, remove the tape.
  • Using the blue handle, lift the ADF rollers.
  • Remove the document.
  • Lower the ADF rollers.
  • Press the two tabs on the document feed-guide assembly to secure the assembly into the proper position.
  • Close the ADF cover.
  • Fax, scan, or copy again.
  • Jan 20, 2010 | Toshiba e-Studio 232 Black and White...
    Canon MX330 - trying to use ADF. No doc inside on
    Canon Pixma MX330, ADF error, Code : 2,103,0
    Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
    The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
    1) In order to CLEAR THE ERROR you need to do two things
    a) & b):
    a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
    b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
    2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
    fails to clear the ADF, generates an error, and must be manually cleared before the next job.
    The rest of your pages will have already scanned.
    Repeat Every Time You Use it
    Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
    74 people viewed this question
    old marine
    old marine
