I forgot the startup / CMOS password for my Sony VGN-TX17GP laptop, at start up it prompts to "enter password", I tried all my passwords with no luck, can anyone help here please?
  • 33 Answers
If for some reason it went back to the default you should try one of these:
  • AMI
  • Award
  • bios
  • setup
  • cmos
  • concat
  • AMI_SW (case sensitive)
  • AMI!SW/
  • AMI?SW/
  • j262
If that doesn't work you can reset your BIOS by removing all power to it (you would need to open your laptop and locate the battery that powers the BIOS), or applying some jumpers or ultimately solding them
If you have access to your laptop you can run a tool to reset it. PC BIOS Security and Maintenance Toolkit used to do the trick but not sure you can still find it online.
Posted on Mar 17, 2011
  • bolitzk Mar 17, 2011
    Another 2 options, just found this:
    Sony PCG series can be unlocked by last 7 digit from Sony VGN-A series after 3 tries it generate random xxxx - 4-hex code Sony VGN other series after 3 wrong tries it generate
    random 5x4 code, do not turn off laptop until get master password
    and you can always call SONY support and ask them for a Master Password.
Windows error recovery message at startup, tried one key recovery takes me strate to enter my password,i dont have one
Hello, If you don't have your password then you will have to remove your motherboard's cmos clock battery for a few seconds and replace it back. This disables your password..
How to remove a laptop cmos battery.
laptop cmos battery
Hope this helps.
Jul 03, 2015 | Lenovo IdeaPad U550 (374955U) PC Notebook
I forgot my password
Forgetting your User password is both annoying and easily fixable.
Turn laptop on and repeatedly hit F8 till a black screen with white writing appears with multiple options for you to select.
Highlight "Safe mode with command prompt" after a few minutes another screen will appear with the following.
C:/ Yourcomputersname/Your user name>
type "net user" press enter
type "net user Your user account name * "
(( Your User Name should appear under neath the "net user" command.
Type "net user Your user name *
It will ask you to enter a password, enter any password you like. Note the cursor will not move to show it recognised a key press this is for security purposes so please dont make a mistake.
It will ask you to re enter the same password
Re enter password then press enter
COMMAND COMPLETED SUCCESSFULLY should appear.
Reboot laptop and sign in with original User Name and new password you typed in above.
Nov 30, 2013 | Sony VAIO VGN-B100B Notebook
I forgot my sony vaio bios password
Remove the battery, remove the power cord and start taking the laptop apart. You will need to remove the CMOS battery located on the motherboard and let it sit for an hour or two. Then but it all back together. The CMOS battery is a silver battery about the size of a nickel.
Mar 24, 2012 | Sony Vaio P VGN-P530H Netbook
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    I need bios password
    Remove the CMOS battery ,wait for 30 secends and and again start.
    To disassemble follow the bellow links.
    http://www.insidemylaptop.com/disassemble-sony-vaio-vgn-bx-series-laptop/
    http://www.laptopparts101.com/cmos-rtc-battery/
    http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
    http://shopping.microbattery.com/s.nl/sc.2/category.763/.f?sendroicid=eb19116b-0e44-4ecf-b82d-e596f32a01ea&sendroikwd=notebook+cmos+battery&gclid=CN_DnuzolqYCFUUb6wodORuwLw
    Hope it will help you.
    Dec 31, 2010 | Sony VAIO VGN-FJ180P Notebook
    I have forgot vaio vgn-cr390 bios password
    To reset the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
    Dec 01, 2010 | Sony VAIO Notebook
    I forgot my bios password. Need help!
    Hello sir, hi, most laptop and desktop computers BIOS is powered by a cmos battery, removing this battery and power on the unit will clear the cmos momentarily. including no password. BUT removing the battery needs dissassembly of the laptop. Some laptops the battery is under the keyboard, if this is not your options try google and search removal bios password.
    Oct 27, 2010 | Sony VAIO VGN-FZ470E/B Laptop
    Sony ,VGN-AR605E onetime password
    Remove the CMOS battery and replace it after 5 minutes. It will reset your bios to default configuration. :)e421fa4.jpg
    thanks to electronic clinic for the image
    Mar 09, 2010 | Computers & Internet
    Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
    I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
    Oct 11, 2008 | Computers & Internet
    Startup Password
    It is simple turn off your laptop.Restart and press the F8 key repeatedly until you get a menu that has an option to go into safe mode. Select the relevant option number then press enter.
    Then it wont ask you for any password,just go to control panel>user accounts>add or remove user account,here change your password or remove it. Thats it you are done,shut it down and thn restart it and at your welcome screen enter da new pass.
    Goodluck,
    Dont forget to rate me as fixya...
    Jan 01, 2008 | Sony VAIO VGN-A150 Notebook
    Computers & Internet Logo
    174 people viewed this question
    David Payne
    David Payne
