Question about Mtd Garden
I have a yardman 1500 edger (yr 2003) That won't run unless I put fuel into intake,then shuts down. I changed fuel lines, primer & took apart & cleaned carb. No help.\r\n What am I overlooking? Thanks for yor help!!!!
  • 59 Answers
Make sure the gasket between the carb and cylinder is ok and the carb is not loose. there is a small hole in this gasket to work the pump in the carb by crankcase pulses, make sure this is not restricted or misaligned and is the right way up.
failing that you will need a carb rebuild kit, these cost very little and are a service item. i change them with every machine service.
Posted on Mar 16, 2011
ST-80 weed eater is not getting fuel unless I put some gas in the air intake.I don't see how the fuel Is't getting past the intake like it's supposed to.
have you checked your fuel picup line in the tank ...check all rubber hoses for cracks..and the primer bubble if it has one.filter in tank could also be pluged....
Sep 14, 2016 | Garden
Bulb doesn't release even with fuel lines disconnected. Completely took carb apart and everything looks good.
If you took off the fuel lines and the primer bulb will not re-inflate than the problem is not the Carb, it is in the lines or in tank fuel filter. Fish the filter out of the tank with a piece of wire to see if that is the issue. Also take each of the lines off of the bulb clean them and try to put some air though them. If they do not let air in easily then that is the problem. The next issue would possibly be the diaphrams located inside the carb, there are two of them and are easily replaced. All the parts to replace those pieces are usually easily found at a local hardware store. Hope this helps.
Aug 06, 2013 | Garden
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I was given a 31cc craftsmen grass trimmer that starts but won't stay running.When I took it apart it has 2 lines coming from the gas tank.One goes to a primer bulb then the carb and the other line has...
The basics of the fuel line on these and many 2 cycle engines is this, one line from the tank goes to the primer bulb and the other from the tank is the return line from the carburetor. There should be another from the primer to the carb. The primer pushes fuel into the carb and any excess flows through the carb and back into the tank.
I hope this helps.
Jun 21, 2010 | Homelite Mighty Lite Lawn Trimmer
Poulan Trimmer PPB100 fuel lines
The larger of the fuel lines is the main fuel line. It is the one that has the filter stuck in the end of it and runs out the larger hole in the tank to a fitting on the carb. The smaller line should be about one inch into the tank and comes out the smaller hole and runs to one of the nipples on the primer bulb. Press the primer bulb and put your finger in front of the fittings. The one that you feel air coming out of when you do this is the fitting that runs from the primer bulb to the carb. Hope this helps and good luck.
Jul 15, 2009 | Craftsman 25cc Gas Line Trimmer
I re-tubed my trimmer and now the bulb won't prime
I had exactly the same problem. On my weedeater, there is a screen in the carb under the primer bulb that was dirty from the fuel line falling apart. After replacing the fuel line AND cleaning the screen, the primer bulb will move fuel and it runs great.
Jul 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman edger won't start
Does it have a primer bulb? If so, make sure the bulb is not cracked. Also, make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. You can buy replacement fuel line/primer bulb kits for under $10 at practically any hardware store.
May 24, 2009 | Craftsman Gas Mini - Tiller/Edger
Garden Logo
169 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
