Question about Panasonic PT-61LCZ70 Television
Looks like we need a new lamp for our T.V. When I attempted to order from your website, I could not select this part. The model number is PT-61LCZ7-K The part number that was listed is LFS54000PA1
I was finally able to order thru a company in Alexandria, VA called Belmot TV
Posted on Mar 28, 2011
JVC REPLACEMENT LAMP : HD-566787205
Please get the correct model number (one posted here has too many numbers--label is on back of set)
GOOGLE THE MODEL NUMBER WITH THE WORD "LAMP" AND YOU WILL FIND (if available) the lamp and several places selling it.
Mar 23, 2012 | JVC HD-52Z575 52" HDTV
Older model Weedwacker Trimmer/Edger with flip switch on shaft that converts trimmer to edger. No serial/model number/manual. Need to order the metal guide (curved, v-shaped) that fit under shield. ...
You will probably have to find someone who has the same model or a different model but has the part that looks the same and get there model numbers. You may just need to take a good look at yours and go to Sears to see if theirs are identical. Then get the model number information and order your parts. You can order by searching Craftsman parts and going to the Sears website and entering the model number and finding the part on the illustrated parts diagram and then look to the list at the right of the screen and find that number to get your part number to order. You will be able to order or if you look at the top of the page (i think) you can call order if you prefer.
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
DEBBILS@COMCAST.NETwhere is my light bulb it burned out. I have a ge compact microwave oven. Model number is JES 1139WLO3
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My 65 in tv turns on but the screen stays black
I am sorry to here about the problem that you are having. I will be happy to help you in any way possible.
It seems that the lamp has went out in you TV. You need to order a new lamp from Mitsubishi, the part can be ordered on the web at
www.mitsuparts.com , or by calling 1 800 553 7278. The part number of your lamp is 915P061010.
Now you will have to follow step by step instruction below in order to replace the lamp.
  1. Turn off and unplug the TV
  2. Located the a little panel on the back of the TV held on with two screws. This is the lamp compartment.
  3. Once you have removed the door, pull out the lamp assembly.
  4. Remove the lamp
  5. Inspect the lamp assembly as this may need to be ordered as well
  6. If it looks good clean all dust and dirt with a cloth, vacuum or can of compressed air
  7. Install your new lamp in the lamp assembly
  8. Install back in the TV and put the door on as to assure not to get burned or shocked
  9. Plug back in and enjoy the TV
You should also inquire with local recyclers as what to do with the lamp and it may contain gases that are not good for the environment.
I hope that I have been of some assistance and look forward to answering any question you may have in the future. Thank you for using FixYa.
Mar 02, 2011 | Mitsubishi WD-57733 57" HDTV
I have Panasonic Microwave oven, model NN-S263WF, serial number 6A63130072, one of the light bulb on the left is burnt out, how do I access it and replace it ? Thank you.
Hope this helps.
Feb 14, 2011 | Microwave Ovens
I cannot find the model number on my televison
Look in the back cover the tv have a sticker, u will find the make and model of the tv.Take that number.Tries websites like Partstore.com,Ebay.com to buy the lamp for the tv.
Aug 02, 2010 | Mitsubishi WD-62531 Projection Television
Replacement Lamp
Click Sony Part and Accessories Store, select model number of your tv in list at top right of page to have required lamp info.
Thanks.
May 09, 2010 | Sony KP-51WS500 51" Rear Projection...
Projector attempts to light the lamp, but to no avail
the ballast is gone and needs replacing. unfortunately, infocus has no parts for that model.
Oct 30, 2009 | InFocus Office Equipment & Supplies
Can't reach AKAI about replacing lamp cartridge.
its very simple small cover on back of tv remove this to replace lamp as its inside new lamp is available a www.replacementlightbulbs.com just be sure to order right one check last digits on seriel number should be a J or Z that will tell you the one to order to reset lamp light push menu then enter
90918988
Feb 11, 2009 | Akai PT46DL10 46" HDTV-Ready Television
My Optoma HDTV Model RD50 needs replacement of its internal lamp. Which model lamp is the correct one and how much does the lamp cost? Regards - Lee
Call Optoma technical support listed on the optomatv website. They will ask for the set serial number. Based on the serial number, they will tell you which replacement lamp is the correct model for your TV. (I found this out after ordering the wrong replacement lamp based simply on the model number of my TV and finding that it did not fit.)
Jan 11, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Panasonic PT-61LCZ70 Television Logo
267 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
