How to change the thermostate on my Rinnia Energysave 556 WT heater
  • 1,420 Answers
The thermostat on the unit is located in the lower right hand side of the unit behind the trim panel closest to the wall. Look for a yellow wire with a black rubber bulb on the end. It will have a few feet of extra wire tied up in the heater itself and allows you to raise it to get a better more accurate reading. To change it, you have to unplug it from the PC board and plug in the new one. You can not use a conventional thermostat on a Rinnai heater.
Posted on Mar 17, 2011
  • 1 more comment
  • oomwoc1 Apr 28, 2011
    Hi, our heater reads the room temp as much higher than the actual room temp, would changing the thermostat as you have described above help this issue? Thanks :)
  • Chandler Ede
    Chandler Ede Apr 28, 2011
    I would lower it. If that does not help, order a new one from Rinnai. They are easy to replace. Good luck!
  • oomwoc1 Apr 29, 2011
    It helped a great deal! Thanks!
Rinnai 556 WT gas space heater flashing PF
most modern gas heaters use a code system to tell the operator what the problem is. look for a pattern in the flashing, and then compare that pattern to the literature on the inside of the heaters panel. When you have a diagnosis code, you can follow the appropriate course of action.
Nov 20, 2013 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnia 516tr gas heater cant change temp showing h10 or h11 or time
Check the secondary gas pressure change when the set temperature is changed
Aug 14, 2008 | Rinnai Heating & Cooling
Just need to no what is required to convert a Rinnia energy saver 1001ft space heater from natural gas to LPG?
hi change the burner injector and the pilot and the reg or the spring inside , you should be able to buy a kit for this.
May 07, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
