Question about Whirlpool Duet GHW9150P Front Load Washer
The washing machine flashes F 20 - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
"F20" is a "No Water Detect" error code. This usually means you have very little water entering the machine, or no water at all. The following link explains the error code in more detail and steps necessary to troubleshoot:
http://www.fixya.com/support/r3608632-f20_error_code
If you have any questions, please post back and let me know. I hope this information is helpful to you.
NOTE: Each one of thes washers comes with a technical data sheet inside. The tech sheet lists all error codes, troubleshooting information, wiring diagrams, diagnostics procedures and illustrations. To access, you need to remove the lower toe panel directly below the door. The screws are located under the bottom front edge. With the screws removed, the panel will drop down and can be removed. If the tech sheet is not located dorectly behind the toe panel, it will be affixed to one of the interior cabinet walls.
Posted on Mar 17, 2011
F-20 is flashing on our HE plus 2 front loader washing machine
Whirlpool (Kenmore) 'F16, 18, 20, 21 and 22' all refer to 'control unit failure I'm afraid ;-0(
Sounds like a service call is required, sorry.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 24, 2011 | Kenmore HE2 Plus Front Load Washer
Machine reading F63
I hope a way to delete this code from the screen
I waited for 20 minutes and stopped flashing screen
Will not disappear
Press any buttons after the screen has stopped flashing
Jun 20, 2011 | Washing Machines
Flashing E 20 will not spin
blocked pump, clear blockages from pump and hoses
Oct 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front lead duet sport flashing F-20.
I read one of the stories on the your sight and it addressed the problem I was having. The solution was to push the cancel button which prompted the machine to drain and end. Then I started the machine again to go through the whole wash proccess again. I think low water pressure caused the F-20 error. Thanks for a wonderful web site.
Dec 03, 2008 | Whirlpool Washing Machines
No draining on washing machine
I am not an expert on hoover - mainly hotpoint...but..
To empty your machine of water reset the programmer to Final spin. the machine should empty normally.
On hotpoint if you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Feb 21, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
