Question about Kenmore Washing Machines
Water isn't draining but the hoses are clean. It doesn't sound right.
  • Kenmore Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 16, 2011
Water does not empty from dishwasher
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Maytag MDB9750AWS Built-in Dishwasher
Tip
How to repair or fix a Dishwasher if it doesn't drain
Dishwasher Doesn’t Drain Following a cycle, a small pool of clean water inside the tub is normal. An excessive amount of water means the pump isn’t pumping water out properly, the drain hose isn’t carrying it to the drain pipe, or the house’s drain lines are backed up.
If dirty water spews from the air gap, the drain line is kinked or clogged. (If you’ve recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made; see your disposer instructions.)
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a stiff wire, clean it out. Also check the entire length of the drain hose for kinks or blockages, especially at the drain connection to the disposer or drain line.
2) Once the dishwasher is cool, shut off the power to it, and—if your dishwasher is made to allow this—remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn’t drain properly, the drain hose may be clogged or the drain valve may need replacement. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose or replacing it with a new hose.
on Sep 03, 2010 | Dishwashers
Water won't drain
Hi
Thanks
Rylee
Jun 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Does not drain water out at end of cycle, I have tried cleaning out all the screens,have opened the impeller cover and checked that the impeller is clean and free. When I put together, it runs for 2 or 3...
Hi
Thanks
Rylee
Dec 23, 2009 | Bosch 24 in. SHX33A02 / SHX33A06...
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Neff 24 in. S5456 Built-in Dishwasher
My dishwasher keeps washing, doesn,t go through the cycles, i have to push cancel and drain.
Hi
Thanks
Rylee
Oct 27, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Have model du460-02. Start to wash but
Hi
Thanks
Rylee
Oct 27, 2009 | Dishwashers
Will not drain water out of tub
Hi
Thanks
Rylee
Oct 26, 2009 | Kenmore Dishwashers
Washer wont drain
Hi
Thanks
Rylee
Oct 13, 2009 | Whirlpool Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
