What is the biggist memory (ram) can i put into a foxconn int-831 motherboard
    Problem Solver:
  • 14 Answers
4GB if you are running a 32-bit OS, and 16GB if you are running a 64-bit OS.
Posted on Mar 16, 2011
I have a winfast foxconn motherboard K7s741mgwould like to know exactly what the memory specs are for this motherboard is it PC2700 or what
Hi there.
The memory that your motherboard can take is DDR memory. According to a spec sheet it can take PC2700 (333MHZ) or PC3200 (400MHZ) memory. I hope this helps. If you have a RAM module already in it I would suggest getting one that has the exact same spec.
Sep 14, 2011 | Foxconn WinFast K7S741MG Motherboard for...
I have a Foxconn 848P7MB-S. just bought the motherboard. i hooked it up today and it turns on all the hdd lights come on the fans all come on but there is no picture. I have tried putting 2 good graphic...
How old are your motherboard and all of its hardware parts?
Is your graphic card is new? If your answer is yes, you have a problem with the ram.
Remove the ram from its memory slot.
Try to clean the ram gold pin with an pencil eraser. clean it horizontally and gently clean the dirt away.
Place it back again to its memory slot.
note: if its not working, remove the ram and replace it to another memory slot
Same as from the graphic card if you got a fail over graphic card use the procedure above
Jul 26, 2011 | Foxconn 848P7MB-S Motherboard
How frecquecy it must to have from RAM ? how nvidia it is OK from mpga478b ?
The Foxconn K8S755A6ELRS motherboard uses DDR Sdram at a frequency rate of either,
266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
The Maximum Total Amount for the motherboard is 3GigaByte (3GB)
There are 3 Ram Memory slots.
The Maximum Amount for EACH Ram memory slot is 1GB.
{Has an AGP expansion slot for a graphics card.
Uses AGP 8X graphics cards}
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?id=en-us0000066
Under the Related Links heading to the upper right, the;
A) Motherboard manual
B) Drivers
C) BIOS update
D) Sample of the manual for disassembling is listed.
(Among other things)
Regards,
joecoolvette
Dec 10, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
I own a dell. intel865 foxconn motherboard. there is on 512 ram and i want to put 4 kingston 512 or at least 2. but there is only multiple long beeps, phoenix bios
You have to make sure that the memory you put on each socket is a DDR266/333/400 memory. The max capacity of your motherboard is up to 4GB, meaning 1GB of each socket.
Oct 12, 2010 | Foxconn 6100K8MA-RS Motherboard
I have a Foxconn Motherboard. UYD8513801460PC661MO5-MX-6LS. Memory is DDM256MBDDR. I want to upgrade to 2GB how many pins should the memory card have. A F Edgecombe
check ur motherboard manual how much RAM it can support, guess it will have 2 slots for RAM so u can have 2 RAM cards of 1mb each...
ur motherboard manual will tell u the pins the rams should have...
DDR pins are of 184
Dec 14, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Motherboard memory capacity.
the motherboard will automatically detect it, make sure that you always use the same manufacturer, speed and size ram chips, don't mix and match. Go to this site and run the scanner and it will tell you what you have and what exactly you can put in it.
http://www.crucial.com/
Jun 16, 2009 | Foxconn 6627MA-RS2H Motherboard
Foxconn m/b memory capabilities?
YOU HAVE TO CALL THE MANIFACTURE OF YOU PRODUCT AND ASK TO SEE IF THE SYSTEM WILL SUPPORT MORE MEMORY
LETS SAY YOUR USING VISTA 32BIT, SHARE VEDIO UP TO 860MB, MOST SYSTEMS WILL ALLOW 3-4 GB, BUT SOME MANIFACTURE SYSTEMS MAY ONLY ALLOW 1 GB RAM, THE BOARD MANIFACTURE MAY SUPPORT 4GB BUT THE MANIFACTURE MAY ONLY ALLOW 1-4 GB OF RAM.
CONTACT ME IF YOU NEED MORE HELP
Jan 27, 2009 | Foxconn 6627MA-RS2H Motherboard
Memory upgrade
Hi Dave,
Foxconn 945G7MA-8KS2
Memory (Page 10 in user manual).
This motherboard includes four 240-pin slots with 1.8 V for DDR2. These slots support 256 Mb, 512 Mb and 1 Gb DDR2 technologies for x8 and x16 devices, and support maximum memory bandwidth of 8.5GB/s using DDR2 533 memory,
10.7GB/s using DDR2 667 in Dual-Channel interleaved mode, You must install at least one memory bank to ensure normal operation.
Need you're manual? Click on the link below.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=945G7MA-8KS2&TypeID=en-us0000001
Foxconn 945G7MA-8KS2 motherboard main page link.
http://www.foxconnchannel.com/Product/Motherboards/detail_overview.aspx?ID=en-us0000024
To upgrade with 1GB. This includes S/H. (Free S/H).
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80098-35
TigerDirect less S/H. (S/H not included).
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1026780&CatId=1647
I did find others for less on the surface. Untill you go to check out & get slammed for shipping (ground), falls between $4.99 to $9.99. I use Corsair myself. Never had a problem.
Have more questions, feel free to ask.
Mike
Apr 18, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Motherboard query
If this is your board, it only has DDR support upto DDR400 (pc3200) upto 2gig, not DDR2 support.
All the rest of the specs are on the page anyway, so pointless repeating them all.
Apr 16, 2008 | Foxconn (865G7MC-ES) Motherboard
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
