Question about Samsung RF266AB (25.8 cu. ft.) Bottom Freezer Refrigerator French Door
I have a bottom freezer, with the one touch pure water on the inside, side panel of the refrigerator. something under the blue rubber button is broken. Can this be replaced and what part do i need? s
Had the same problem. I just ordered a replacement piece from this website. Looks like it just snaps in. http://www.repairclinic.com/PartDetail/Dispenser-Actuator/DA9704952B/2049390
Posted on May 23, 2012
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
SOURCE: Samsung Refrigerator
I have a RS2544SL side by side Samsung with a defrost sensor failure light upon a plug-in reboot, according to the service manual, which I purchase from Samsung so that I could help a local service provider unsuccessfully fix the unit.
The unit was less than 3 years old when I started having problems. The freezer side works although the unit will not re-boot following a power outage because is hangs-up on the defrost sensor flashing light on the front display.
Samsung service providers have stopped working on Samsung refrigerators and Samsung would not suppor the repair.
I had an independent service provider install a new defrost sensor but the reboot-pluging program still hangs-up at the defrost sensor despite a newly installe defrost sensor from Samsung.
The freezer side continues to work well and problems continue with the refrigerator side. The unit continues to fail during power-outages because it hangs-up on the warning light. I by-pass by holding both power freeze and power refrigerator buttons for 10 second as described in the service manual. After by-passing the warning light, the performance of the refrigeration side continues to be unreliable.
What is my next step to get my relatively new Samsung side-by-side refrigerator fixed, since Samsung will not back their warranty and Costco where I bought the unit also will not backup the warranty and purchase.
Posted on Jun 11, 2008
  • 50 Answers
SOURCE: Mullion between freezer and refrigerator is extremely hot.
They rarely use 'heaters' anymore. If there is a heater there will be somthing like a 'energy saver' option to turn it off. More likely it is a mullion loop that is part of the sealed system tubing. The harder the frige works the hotter that area will be. So if the inside temp rises so will the temperature of the mullion. Start by checking your frige and freezer temperatures with a thermometer. The freezer should be between 5-10 deg ABOVE zero and the frige should be about 35 or 36 deg. Also check that the condenser is not dirty. The condenser is the coils that are usually underneath the frige. They should be cleaned at least annually. Also while you're under there make sure the condenser fan is running. You should feel a little air movement and possibly hear it running from the front under the doors. If it's not running you'll need to find out why, but would usually be a problem with the motor. Also there was a carboard panel on the back at the bottom of the frige from the factory, that panel HAS to be in place to direct air across the condenser and not back behind the frige.
Posted on Jul 19, 2008
tborn6
  • 700 Answers
SOURCE: SENSOR PROBLEM ON SAMASUNG SRS580DW (side by side fridge)
go ahead and take and hold in the top two button until the unit blinks and resets the controller. Please don't rate this unitl the problem is solved because i can't come back and answer any more questions then. Also if this fix's please rate this solution please. Thanks for usin FixYa
Posted on Jan 01, 2009
tborn6
  • 700 Answers
SOURCE: flashing temp on freezer door
take and press the two top buttons on the control panel and reset the unit. it appears the the freezer is not operating properly and may by frozen up
Posted on Mar 23, 2009
Water is running down inside of my refrigerator
If this is a top freezer with refrigerator on bottom the I would say most likely you have a plugged drain. Remove the back panel inside the freezer by removing the few screws on the back wall and pull the cover off, check the drain hole on the bottom under the evaporator and see if it is iced over or something in it.BE SURE TO UNPLUG REFRIGERATOR BEFORE TAKING OFF THE BACK PANEL INSIDE THE FREEZER AS THE FAN WILL BE RUNNING AND YOU DO NOT WANT TO HIT IT! Good Luck!
Jul 18, 2015 | GE Refrigerators
Water leaks on the floor. i Is there a tray that
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Nov 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water and ice in bottom of freezer, occasional water on floor
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Maytag side by side (no icemaker) keeps leaking water under the freezer side front roller area. Ice is forming on the inside bottom of the freezer under the bottom basket. I've vacummed underneath and...
OK, You need to unplug for a hour or so. Remove the rear panel in back of freezer to expose the evaporator coils. At the bottom of the evaporator there is a tray that catches the defrost water to take it through the back and down to the condensate tray located near compressor and condenser fan. Most likely you have ice or something trapped in that drain beginning in the freezer. I have heard some people turn the freezer temperatures so cold ice will form before the water can drain. If you still have problem contact me. If this helped vote or rate me. Thanks Sea Breeze
Jun 22, 2009 | Maytag MSD2732GR Side by Side Refrigerator
My freezer is leaking inside the freezer area. I took off the panel on the inside and can see that it is leaking by the top of the coils. The water then freezes at the bottom of the freezer. Again all this...
This water comes from the defrost cycle. The drain hole is probably plugged with food. The drain usually goes to a small pan under the condenser where it eventually evaporates. Look for a hole or slot in the bottom of the unit.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leakig out of the top panel in freezer by the light.
the back panel need to be open (inside the freezer ) and see if there is build up of ice there the make it, also :
your freezer cabinet need to get all out also the ice machine,and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com
Feb 17, 2009 | KitchenAid KSCS25IN Side by Side...
Water leaking from bottom left freezer/dispenser side
Take the metal back panel off the inside of the freezer, exposing the cooling coils. Below the coils, at the very bottom of the freezer compartment you will find a small drain hole. (Presently covered over with ice) Use hot (not boiling) water and a turkey baster to melt the ice and force hot water into the drain hole until the water runs out the drain hole (and into the defrost drain pan under the refrigerator) on it's own. This should be a Fix-Ya for your refrigerator.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water puddling in bottom of freezer which freezes
Tool needed: Screw drive with the insert tips can be used to remove screws use the end of the screw driver with out a philips bit or flat tip inserted. Remove frozen food to camping coolers igloo ice chests or coleman ice chests or a freezer in your home . Remove all racks and baskets to expose movable panels at the inside back of the freezer compartment.
Notice the 1/4" hex nuts remove the screws holding the panels at the back wall. Clear built up ice carefully. You now can take out the panels and expose the fan and cooling cool that creates the cold temperature on the freezer side.
Near the bottom is an aluminum U shaped pan with a shallow funnel indentation at the bottom. Clear ice from the funnel pan and inside bottom carefully. Sharp objects break ice nicely and can pierce the interior surfaces . Look under the cooling coil and at the back wall is a screw holding this soft metal catch pan in place. Remove the screw and carefully tip and slid out the catch pan tray. You now have access to the drain hole that is frozen closed or clogged. Place a large towel in the bottom of the freezer area to catch water. Pour hot tap water a half cup at a time into the drain area. Do not use boiling water the plastic inside a refrigerator or freezer can not tolerate high temperature. I have melted a freezer compartment in a GE with a hair dryer. Remove the water with a clean reag and add more warm or hot water repeat until the drain allows water to flow. stop adding water or the evaporation pan under the refrigerator will over flow.
Check the refrigerator about once a year for the freezeup problem or keep an eye on the bottom of the freezer looking for the build up of water frozen on the inside floor. The other solution get a new refrigerator.
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerator
I just fixed similar issue. Defrost drain plugged. Take back panel off and behind fan is back hose. Take it out from the bottom and use something like coat hanger to unplug.
Also need to take off front panel from inside freezer and remove ice build up and thaw with hot water or hair dryer. Once done you should notice water in drain pan from back. Put all together.
Feb 01, 2008 | Frigidaire FRS3R5EMB Side by Side...
Samsung RF266AB (25.8 cu. ft.) Bottom Freezer Refrigerator French Door Logo
854 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
