Question about IBM 10 Bays ProFibre Storage Array DL1100J (07K6013) SCSI Storage Cabinet
Where can i find the driver for my IBM DF 1100 r scsi enclosure device?
  • rjettjr Mar 17, 2011
    we are using windows server 2003, the system is looking for the device driver call IBM DF 1100R SCSI enclosure Device in the hardware section of windows.
  • IBM Master
  • 8,404 Answers
You don't say what OS you are uding ... Please have a look here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
You will find similar lists for all currently supported MS OS ...
You might also check at www.ibm.com/support
Thanks for your question @ FixYa.com
Posted on Mar 16, 2011
I cant intall window 2003 in IBM server x3400 , wher to find the SCSI driver < took me 24 hours and i didnt find it yet anyhelp thx.....
You can install Windows 2003 using IBM Service Guide CD. Its an image file (.iso) . Burn it after download . Then boot from cd and follow the simple wizard . Find the link below
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5088993
Thanks
Nov 15, 2011 | IBM x3400 Server
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
How to repair server 2003 in IBM 226 server
first you need to prepare the scsi drives ie host raid adapter scsi drivers are server raid cotroller 6 scsi drivers by using the serevr raid support cd dikettitools proper os drivers to floppy and boot with widows cd at the time starting boot press f6 to specify the scsi drivers then all scsi hdd will detect for installatio.
Jan 18, 2010 | IBM xSeries 226 Server
Does not see hard drive
configure the bios settings, hdd should be scsi. maybe your current settings is sata or ide. if not work check the scsi controller if have installed driver or compatible to your unit.
Oct 10, 2009 | IBM IntelliStation Z Pro 6223-31U PC...
Platen Cover is open
if you open the platen cover, on the rear middle there is a little opening, that is where a little actuator sensor sit, and it is sticking... take a little flat screw driver and kinda flicker it.... that should take care of your problem
Jun 20, 2009 | Panasonic PanaFax DF-1100 Laser Printer
Prolinat ML350 G2 WONT BOOT UP
You have apparently attempted to attach a tape drive or other similar device to a SCSI RAID controller. You will need to get a separate SE SCSI HBA instead. These are pretty cheap, usually just over $100 list from HP.
If you haven't attached anything new, then you should check your cables first and if that doesn't help I would suspect a bad RAID controller.
Jun 10, 2009 | HP Compaq ProLiant ML350 G5 Server
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Windows 2008 on IBM x346
I used this one with good result:
http://www.adaptec.com/en-US/speed/scsi/windows/a320raid_win2k8_x86_b212_exe.htm
Nov 11, 2008 | Microsoft Windows Server Standard 2003 for...
IBM IntelliStation Z Pro 6221
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
Jun 18, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM 10 Bays ProFibre Storage Array DL1100J (07K6013) SCSI Storage Cabinet Logo
403 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
