It sounds like the water level switch has gone faulty on you. It is connected to the drum by a plastic pipe. If you blow lightly into it you should be able to hear the switches operating. Check that the pipe is not blocked and that the switches operate. What you are looking for looks something like this:-
The air gap is only there to satisfy UL requirements. If you eliminate it with a couler and clamps, you can use the washer.
Thanks! Why did it start overflowing in the first place... it did not seem broken or worn, and there were no obstructions in the line. I am worried that there is an inlet pressure valve or regulator that is allowing the water to come in at too high of pressure.
Hans, it did not include a picture. I will ask my husband to read it to see if it is enough info to repair... He bypassed it and the washer is really shaking when it spins, and the water pressure is different with the bypass.
Excellent feedback, speedy response!
