Question about Thermador MASTERPIECE ME302EP Stainless Steel Electric Double Oven
1993 built double oven-model CT230SA-serial#95020274-E6 error appears-cannot raise baking temp. in upper oven. Lower oven functions properly. thanks, john
Powerman
  • 68 Answers
SOURCE: GE JKP27WP1 Oven Won't Work
Hi Cyrep,
You can fix a suggested fix at the following link:
www.fixya.com/howto/h155060-dreaded_f7_error
Even though you are not getting an error message, they are sometime stored in memory and have to be repeated a number of times before they show up in the display. I have shared this fix with over 1300 folks and most report success. I hope that it works for you too. Please let me know at hutchipop@yahoo.com.
Regards,
Charlie
Posted on Oct 16, 2007
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
SOURCE: I HAVE A RBD305PDB DOUBLE WHIRLPOOL OVEN AND IT
WHEN MY OVEN KEPT BEEPING AND LATER IT WOULD NOT OPERATE, I CALLED THE LOCAL COMPANY WHO SOLD MT THE OVEN...(KITCHEN CONCEPTS), THEY FORWARDED ME TO THEIR SERVICE COMPANY WHO CAME OUT AND LOOKED AT THE ERROR CODES AND SAID, "THERE IS NOTHING BUT BAD NEWS) THE CIRCUITS IN THE OPERATING CIRCUITS HAVE BEEN BLOWN OUT BY SURGES...IT WILL COST $538 TO REPLACE THEM....HIS STORY WAS THAT IN OUR NEIGHBORHOOD, THERE ARE A MULTITUDE OF SURGES...MY QUESTION IS WHY THE HELL DOES WHIRLPOOL PUT OUT A $1100 OVEN WITH NO PROTECTION FOR SURGES....CHECKING ON THE NET, I SAW MANY BAD FEATUIRES ON MY OVEN....DON'T USE THE OVEN CLEANER AS IT WILL COOK YOUR CIRCUIT BOARDS AND SEVERAL OTHER....WHAT A PIECE OF ****....I AM GOING TO WRITE THE COMPANY AND *****....TO NO AVAIL, THANK YOU FOR YOUR HELP....
Posted on Mar 06, 2010
Daniel S
  • 4323 Answers
SOURCE: My GE double electric oven
Hi
If the error code still appears, then the problem is likely in the control module (circuit board) behind the keypad and clock. You'll need to remove the bezel to get behind the control panel. Remove the screws & lift the panel up about a half inch and pivot it forward toward you. The circuit board you can now see is the Control module. Check for the black square shaped components on this board, they may be burnt or the connection might be loose. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 11, 2010
  • 13 Answers
SOURCE: I have a double KitchenAid superba built-in oven,
there should be separate fuses for the top and bottom oven. check all of them if this is not the problem maybe your burner in the bottom oven is burnt.
Posted on Dec 09, 2010
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
I have an error code of E6 and F2 on my whirlpool accu-bake oven display panel. What do they mean.
Hi
F2-E6 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Ovens
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
GE Oven MODEL J KP27WOP2 WG - WILL NOT HOLD TEMP
You can re-calibrate the oven as follows;
press BAKE pad.
select temp of 500 degress or more.
immediately PRESS and HOLD the BAKE pad until "00" appears.
Then press the + or _ pad to adjust temp up or down 5 degrees at a time.
When fimished press the Clear/Off pad.
Mar 15, 2009 | GE JTP15 Electric Single Oven
Jan 30, 2009 | Thermador Ovens
Upper oven not working
thismay be caused by a few issues, either the bake elemnt has gone bad, or a high temp thermo has gone bad not allowing element ot come on.. have to remove the oven from the opening and acces t he rear panel to check either
Nov 25, 2008 | Ovens
Thermador MASTERPIECE ME302EP Stainless Steel Electric Double Oven Logo
44 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
