Question about Nintendo DS Lite Console
I have replaced the hinge on my daughters DS Lite and put it all back together (didn't realise it would be quite so in depth!). I've tried charging it from the car (as have lost the indoor charger) and tried turning it on and the lights come on but the screen just flashes and goes off again. Any ideas - do I have a loose connection inside or have I done some major damage? I was extremely careful! Thanks
  • 44 Answers
It sounds like the connections at the hinge either are damaged or are not reconnected properly. You might try taking it apart again to make sure you didn't miss a connection, and if that doesn't work I'd contact Nintendo or a third-party repair center to see about getting it repaired professionally.
Posted on Mar 16, 2011
Brought a ds lite and new ds shell as the old one had broken hinge.Whilst re routing the black antenna cable broke (gold connection bit came off) i have ordered a new one from ebay.So as this is just for...
If you yourself have replace it, I think you damage the upper LCD ribbon connector. I have repaired a lot of DS, a broken hinge usually the cause of that problem( ribbon connector cut off ).
Check the upper LCD if that model have a seperate ribbon connector, luckily you could buy the ribbon only, if not, BAD LUCK, you have to buy a new upper LCD.
Hope that helps you out.
Thanks for asking FixYa!
Aug 08, 2011 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
I have a Nintendo DS Lite that needs a new housing. It works fine, just the rounded hinge on the right is bent and cracked because it was dropped. Can a local repair shop put a new housing on, or do I...
Go to this page on Nintendo's website. Regardless of your warranty status, they will offer repair options.
"Nintendo DS Lite - Plastic Housing and Hinge Issues
If your Nintendo DS is experiencing issues with the plastic housing (such as a cracked hinge), please contact our Consumer Service Department at 1-800-255-3700 so that we may provide you with repair options."
Nov 30, 2008 | Nintendo Computers & Internet
DS Lite Completely crashed
Some R4 cards were known to "brick" DS's. Not sure if they were defective or made that way. So it looks like your DS is dead. Unfortunately, this is the risk you take when you use 3rd party hardware.
Aug 24, 2008 | Nintendo DS Lite Console
DS won't charge!
Bluesbelle,
Are we talking here about a DS or a DS Lite?
Jul 24, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
Nintendo ds lite
Hi  Im  Patrick here  to  help.First  go  to  a  GAMEFREAK  store
Mar 14, 2008 | Nintendo DS Lite Console
Top Screen Replacement of DS Lite
there is a video tutorial at http://www.maxconsole.net/?mode=news&newsid=11484
which tells you how to disassemble the ds lite
Dec 04, 2007 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
82 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
