I am trying to use drivescrubber on a dell laptop and after the initial drivescrubber screen goes by I get a 'remove diskette in drive A: followed by Insert diskette in drive B: then press any key to continue.... And again the same thing. There is now diskette drive in the laptop..??????
    President:
  • 1,768 Answers
1. the software you are using is not compatible with your operating system and is looking for a disk drive.
If you have a recent operating system then this software will not work.
It needs to see a floppy drive.
Posted on Mar 16, 2011
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
My computer keeps reading diskette 0 seek failure on a black screen and wont start how do I fix this issue. I have a dell desktop computer
You might get this error if there is a non-bootable diskette in the drive. Remove it if so and you might have a normal star-up.
If there is no diskette in the drive, you may have a hard drive failure where the computer can't start normally and is switching to try the floppy.
Apr 13, 2013 | Dell Vostro 200 PC Desktop
This was the question I posted a hour or so ago: I am trying to use drivescrubber on a dell laptop and after the initial drivescrubber screen goes by I get a 'remove diskette in drive A: followed by...
Here are two things to check. If it is a Dell Laptop, most likely the F2 key will get you into set up before any OS loads. If it is not F2, just watch the screen right after you power the device on, you will see insturctions that say "Press F(something) to enter setup".
Once in set up, scroll down to the "Drives" section. Highlight the floppy drive and make sure that it is set to "off". Regardless of the fact that the laptop has no physical floppy drive, chance are there is still an option under set up. It may be set to something like "internal". Dell actually uses an "internal" floppy setting when imaging their machines.
If you are using Drive Scrubber from a CD, which I presume you are, you can also check the boot order while in setup. Once you highlight it, you will be able to see the order the computer uses to try and boot from. I would move the CD drive up to the top and you should boot from the disk before it even tries anything else.
Mar 17, 2011 | Computers & Internet
Computer: dell dimensio c521 problem: when i turn computer it goes to a black screen stating: "diskette drive 0 seek failure" and below it says: "Press F1 to continue, F2 to enter SETUP. i pressed...
Please follow the below stesp:
Enter the setup, and there will be a setting in there somewhere called "Halt On" and if you set that to "No Errors" the computer should boot fine.
This works with Dell computers.
Diskette drive 0 seek failure — See "Drive Problems" in your Owner's Manual.
Apr 01, 2010 | Computers & Internet
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Formatting problems.
Remove any 3.5" diskette from the diskette-drive in the computer.
Insert the Recovery Disk into the CD-ROM device.
Restart your computer, and *FORCE* it to *FIRST* try to "boot" from the CD-ROM drive, rather than trying to boot from the 3.5" diskette or from your C: drive.
Nov 26, 2009 | Toshiba Satellite A75-S226 Notebook
When i turn on my computer all it says phonix rom bios plus version 1.10 A06 copyright 1985-988 phoenix technologies ltd. copyright 1900-2001 DELL computer corporation ALL right reseved dell system...
If there is a diskette in the diskette drive remove it. It's a bad diskette.
If no diskette in the drive the drive may be bad. Till you can replace it disable the diskette drive in BIOS.
access bios by F2 at boot up and disable the Diskette drive (Floppy drive)
Aug 02, 2009 | Dell Computers & Internet
Floppy diskette seek failure
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
