Question about Pinnacle Dazzle DVD Recorder
I have red, white and yellow leads plus an S video going from the Dazzle to the TV and the TV connected to the VCR by a Scart, I record sound but no picture. Am I hooked up correctly and what do I select in the menu S Video or Video composite ? Do I tick the VCR ? Totally confused ??? Please help.
    Problem Solver:
  • 4 Answers
If you are using "Composite" output the leads are red/white = sound. Yellow = video. If you are using S-video cable then yes you will need to select that option in the menu.
Hope this helps, Dave
Posted on Mar 31, 2011
I have trouble setting up my 50 inch T.V. It is connected to a VCR/DVD player recorder. I have a red, yellow, and white cable. Do I need anything more?
If possible use a AV SCART connection lead as you get audio & video! If you want to use the phono connection you need to connect all 3 red/white/yellow to the TV and the VCR/DVD! Red & white are audio, yellow video!
Dec 19, 2014 | Televison & Video
I have hooked up all cables correctly however when i attampt to record of my xbox i get black and white record screen ive tried 3 diffrent record program im using the HD componet cable (blue green and...
Greets - You are mixing cables up. You need to connect the Dazzle yellow, red, white cables to the yellow, red white cables on the TV. You can't plug standard video/audio cables into the component (red, blue, green) connectors on the TV.
take a look at this diagram, just pretend the devices on the left are all connectors on your TV.
http://www.pinnaclesys.com/presskits/Dazzle/DazzleDVD_Recorder_ReviewersGuide_May06.pdf
Good Luck, Mikeywaf
Mar 03, 2011 | Pinnacle Dazzle DVD Recorder
Trying to record from a vcr to the dvd recorder
Connect scart VCR to scart DVD (full scart lead) or RCA (phono) video out yellow VCR to video in DVD and audio outVCR white/red to audio in. Select the correct input or source to the DVD recorder and off you go.....
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 03, 2011 | Philips Magnavox MWR10D6 DVD Recorder
I purchased a dazzle dvd recorder. it has red and white audio leads ,yellow video lead . my vcr has only white audio. i installed program.followed the instructions. put put dvd and vhs in proceeded to...
I hate these little converters, much more trouble than they're worth.
The red and white leads provide stereo. As with VCR's just having a white phono out is quite common. There's just no connection for the red.
Its then a case of recording to your PC HDD, Edit the recording and saving the file. Finally burning the file to DVD.
You have to ensure that, assuming the options there, that you save your file as MPEG1 or MPEG2 or any file compatible with your DVD player.
In this case it looks like your "burn" failed for what ever reason. I'm afraid that disk is now a coaster. Have another crack, take your time, one stage at a time.
The way I do it, I've got a DVD recorder with a built in HDD.
Hook up my VCR to DVD recorder via scart and loop it through to a TV so I can monitor it.
Press record on the DVD and play on the VCR. When complete, edit the recorded file on my DVD then copy or dub to and finalize the recorded DVD.
Apr 29, 2010 | Computers & Internet
I need help installing a vcr on my phillips 22 in hdtv, and i cant find my user manual and I'm obviously not good at technology
Connecting this up will be easy. What you do is get a yourself a set of the right for your setup, cables that has EITHER one, of these described, below. A THREE way or three separate " Coaxial Cores" Jacks colored Yellow, (Video) Red, & White. (Audio) AV. OR If you have SCART Connection plugs, big Black Socket at rear of unit, you get a SCART cable. It;s all inside. Then you could use that. Some units, have a thing called Component Video, Green, Red, & Blue. Now with the Component setup, Now, you will ,need, Two more Cables, for the AV Audio. Red & White.(5 in all) In any event ALL cables go color to color, at each end, into the corresponding color RCA Jacks on either machine, or VCR or TV. If SCART it simply plus in only one way. It is that simple. So connect up with the leads your set uses, and select the "Input" from TV/Remote and Press "Play" on VCR/DVD whatever.... should be all go.
Feb 10, 2010 | Televison & Video
I would like to know how to connect a dvd player through my samsung vcr the inputs in the back i am not familiar with there are two sets of yellow white and red connections with one side for output and...
Connect from dvd OUT to vcr IN
The yellow connecter is video, red is right audio and white is left audio.
You can purchase converter leads (scart to phono(the red/white/yellow connecters) or many other combinations) if needed.
If you have scart connections ( a block of 21 pins) then use that if possible as it will give a better picture.
Connect the dvd out to vcr in and vcr out to the tv in.
NOTE. if you connect this way you will find that the copyright protection will make viewing dvds quite poor quality and may even be black and white or even the picture may "roll"
You may want to buy a scart block to connect more scarts to the tv then it has, also you can get these with different connections.
Dec 30, 2009 | Samsung VR8607 VHS VCR
How to connect to an analog tv
Try to locate the composite video/audio in(1) and audio (2) out sockets of your tv.
(1): three small round sockets, one yellow, one white, one red (2): two small round sockets, red and white. (only if you want sound from your tv on your marantz receiver)
You will need a composite audio/video cable: 51433a4.jpg
and a composite audio cable: db5db51.jpg
Connect the composite video/audio cable (1):
the yellow lead to MULTI OUT (yellow) the white lead to MULTI OUT (white) the red lead to MULTI OUT (red)
on your tv: connect these cables to the respective yellow, red and white input. (there should be a text like: game in/dvd in/ext in/AV-1/VCR) If all you see at the back is a big socket like this one: 0f41fcb.jpg
you will need a SCART-to-composite adapter, like this:
(2) To get audio from your tv to your Marantz, locate an 'audio out' (red + white round connectors) on your tv, and connect these pins using cable (2) to TV (complete bottom left on your Marantz).
Dec 13, 2009 | Marantz SR7002 6.1 Channels Receiver
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
g
OK,you need 3 leads,(A/V leads),normally red white and yellow.
So yellow is for Picture (video).go from video OUT (combo) to TV video IN.
Then red and white .... Audio OUT of combo into Audio IN on TV
TV must then be set to AV1 or AV2 depending on which AV inputs you used..
Rod
May 04, 2009 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Pinnacle Dazzle DVD Recorder Logo
124 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Computer Links
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
