Question about Air Tools & Compressors
I have a 21 gallon Air Compressor Model 94667 looking for a wheel and bolt ,nut washer, Air filter, foot, Air flow valve, Breather Valve amount =one 7A Air Filter amount =one 12A Rubber Wheel with Bolt amount =one 13A Washer amount =one 14A Nut amount =two 17A Foot amount =one 6A Air Flow Valve amount =one 14B Breather Valve Need cost and shiping cost and avability LeRoy
  • 65 Answers
SOURCE: Twin tank air compressor does not pressurize past 65 to 80 psi.
machine inlet valve not sealing in cylinder head valves need to be removed for assesment
Posted on Dec 03, 2008
SOURCE: Tool side has no pressure
if there is sufficient air in the tank the regulator valve is either set to low or is stuck. if its stuck ur better off to buy a new one and replace the one u have.
Posted on Dec 11, 2008
  • 744 Answers
SOURCE: need to replace drain valve
The "welded nut" is the pipe fitting into which the drain valve or drain plug is screwed. It's usually brass and the valve or plug can be obtained through Sears or possibly and good harwarde store. Be sure to use pipe sealing compound or teflon tape on the threads when you re-install the valve or plug.
NOTE - THE AIR MUST BE DRAINED FROM THE TANK BEFORE REMOVING THE VALVE OR PLUG. ALSO, POWER SHOULD BE DISCONNECTED FROM THE COMPRESSOR!
Posted on Mar 22, 2009
  • 89 Answers
SOURCE: kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Posted on Apr 20, 2009
  • 56 Answers
SOURCE: replacing the pcv valve
See if it's just a rubber grommet pushed over a plastic stud. Maybe spray a bit of something on it and any others it may have - then just wiggle and pull up on the box.
Posted on Jun 27, 2009
Hi I have model 94667 21 gal the pressure is at max,will not go past 60 psi & if I set it 60 the compressive will not stop running but it will hold pressure no leaks.can you help. Thanks Jay
The reed valves are worn. Replace along with gaskets and valve plate. Part #38, 48,58. good luck finding pats. unfortunately the air compressor is disposable, You probaqably never find parts., HF does not have them. Maybe Ebay.
v37sysaytalc8dyukjc4v8blo9prznzf6saaaaasuvork5cyiia
https://www.about-air-compressors.com/support-files/94667.pdf https://www.about-air-compressors.com/support-files/94667.pdf
Mar 30, 2018 | Psi Air Tools & Compressors
21 gal vertical Model 94667 will not fill tank.
Could be piston rings too. Have you looked here? http://www.centralpneumaticaircompressors.com/buying-central-pneumatic-air-compressor-parts/
Oct 14, 2013 | Air Tools & Compressors
Can I adjust the tank pressure on a Husky 1506 compressor. pop off keeps engageing, so I need to adjust so that compressor shut off automatically
Before you change any parts, check that the pop valve is not faulty. Look closely at the pop valve to read set release pressure. If the valve is releasing before marked reading, replace valve instead to one slightly higher. The pressure may or may not be adjustable at the switch (need to replace the switch) depending on switch installed at the factory (parts list does not give enough information). If your switch has a remove-abel cap with adjustment screws/nuts, post again with model number of switch for info on adjustment. Good luck
Oct 06, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
How dose the unloader work on a T30 compresser ? T30 compresser has small air leak sound comming from intake ? Is there a flow chart of how ther air is compressed T30 ?
There is no unloader on a 2340N5 compressor. However there is a pressure switch that cuts the motor on an off. Located inside of the pressure switch is an air bleeder. When the pressure switch is opened the motor is shut off. A small lever in the pressure switch pushes down on the bleeder valve which lets the air on the compressor head to be released. This allows the the compressor to start up freely. There should be some air heard bleeding off at the pressure switch. If air continues to bleed off all the time the tank check valve is leaking.
If air is leaking back thru the compressor an air leak sound coming from around the air filter (intake) you have a valve leaking allowing trapped pressure to escape thru the air filter (Intake).
I would search the web for a flow chart. I have not seen one.
Nov 16, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Oil goes towards the air cleaner in my water pressure. what is wrong?
It is normal for a small amount of oil (usually a smokey vapor) to pass from the crankcase breather into the air filter. However, if your having an excessive amount of oil then the the stem seals on the valves have hardened and it is allowing oil to pass along the valve stem through the valve guide through the breather and into the air filter. The remedy is to replace the stem seals under the valve springs inside the cylinder head.
One other thing that will do it is if someone overfilled the engine crankcase with oil. This will cause massive amounts of oil to be pumped into the air filter.
Thanks for using FixYa.
Kelly
May 03, 2010 | Karcher 2500 PSI Pressure Washer
I was wandering if you might now why my air filter keeps gettin oil soaked
One of the first concerns is the health of the engine. Do we have a tired old engine allowing the blow-by gases to pressurize the crankcase? If so, the pressure would force the oil up the PCV breather hose and contaminate the PCV breather filter and air filter.
The Positive Crankcase Ventilation (PCV) System is one of the oldest and most neglected emission control systems. The valve is a calibrated vacuum leak controlled by a plunger and spring. Contaminates or changes in spring tension can directly affect the flow of the valve, which could result in oil accumulating in the air cleaner or an imbalance in the fuel mixture. Remember: For each gallon of fuel consumed by an internal combustion engine, one gallon of water vapor is created through condensation. Much of this condensation is formed in the crankcase. The PCV system is designed to control this condensation and remove gases which accumulate from the combustion process and collect in the crankcase, in addition to protecting the environment.
Conditions other than a defective or restricted PCV valve can lead to an accumulation of oil in
the air cleaner, sludge deposits, poor performance, or excessive oil consumption.
Check the following:
• The PCV and fresh air hoses are clear and free of obstruction
• The proper valve is selected for the application
• The valve is functioning properly
• The valve fits tightly in its rubber grommet
• Any O-rings or hoses are tightly secured to their mounting
Feb 15, 2010 | 2000 Hyundai Elantra
I have replaced EGR,pvc,plugs,wireset, cap rotor,fuel filter air filter,oil sensor,and my engine still idles high and some times wants to try and cut off.I have also replaced any damaged vacuum lines.My...
check aux air control valve , thats what controls the idle it may be bad,also with that kind of mileage i would replace the mass air flow sensor ,do that first, good luck , the mass air flow sensor has alot to do with your gas mileage .
Nov 07, 2009 | 1993 Nissan Pickup
Hi I have a Central Pneumatic model 94667 air compressor that was working fine, now it will not shut off when it gets to the usual shut off pressure. thanks. George.
make sure it is actually achieving full shutoff pressure. I had the same compressor and had a valve crack and the compressor would run nonstop but never got above about 40 psi.
Apr 14, 2009 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
I need a diagram of a 1995 ford escort engine
96 escort 1.9L
Engine Components
Item Part Number Description 1 6766 Oil Filler Cap 2 6A548 (8 Req'd) Valve Cover Bolt 3 6582 Valve Cover 4 — Exhaust Manifold Shield-to-Exhaust Manifold Nut (4 Req'd) 5 9A462 Exhaust Manifold Shield 6 — Exhaust Manifold Shield Stud (4 Req'd) 7 9430 Exhaust Manifold 8 9454 Exhaust Manifold Nut 9 9448 Exhaust Manifold Gasket 10 — Exhaust Manifold Stud (Fine Thread), Short (4 Req'd) 11 — Exhaust Manifold Stud, Long (1 Req'd) 12 — Exhaust Manifold Stud (Medium Thread), Short (1 Req'd) 13 6518 Valve Spring Retainer Key 14 6514 Valve Spring Retainer 15 6513 Valve Spring and Damper, Intake 16 6C515 Valve Tappet Guide Plate Retainer 17 6571 Valve Stem Seal 18 6513 Valve Spring, Exhaust 19 12405 Spark Plug 20 6269 Camshaft Thrust Plate 21 — Camshaft Thrust Plate Bolt (2 Req'd) 22 — Cup Plug 23 6B273 Camshaft Oil Flow Control Rod 24 6K292 Camshaft Front Seal 25 6256 Camshaft Sprocket 26 6278 Camshaft Sprocket Washer 27 6K252 Camshaft Sprocket Retaining Bolt 28 6L269 Camshaft Sprocket Key (5 x 18) 29 6250 Camshaft 30 6051 Head Gasket 31 6A008 Cylinder Head to Block Dowel 32 6010 Cylinder Block 33 6507 Intake Valve 34 6505 Exhaust Valve 35 6049 Cylinder Head 36 — Intake Manifold Stud (7 Req'd) 37 17A084 Engine Lifting Eye 38 — Engine Lifting Eye Bolt (2 Req'd) 39 9439 Intake Manifold Gasket 40 — Bolt 41 9723 Accelerator Cable Bracket 42 9424 Intake Manifold 43 — Intake Manifold Nut (7 Req'd) 44 9D476 EGR Valve Gasket 45 — Exhaust Gas Recirculation (EGR) Valve Bolt (2 Req'd) 46 9D475 EGR Valve 47 — Fuel Injection Supply Manifold Bolt
(2 Req'd) 48 9F593 Fuel Injector 49 9D930 Fuel Charging Wiring 50 6786 Oil Level Indicator Tube Bracket 51 — Oil Level Indicator Tube Bracket Bolt 52 6754 Oil Level Indicator Tube 53 6750 Oil Level Dipstick 54 9D280 Fuel Injection Supply Manifold 55 — Vacuum Fitting 56 9E498 Main Emission Vacuum Control Connector 57 — Vacuum Tap 58 — Vacuum Hose 59 9B989 Throttle Position Sensor 60 — Screw and Washer 61 9F782 Throttle Position Sensor Gasket 62 — Throttle Body Bolt (4 Req'd) 63 — Idle Air Control (IAC) Valve Bolt
(2 Req'd) 64 9F715 Idle Air Control Valve 65 9F670 Idle Air Control Gasket 66 9E926 Throttle Body 67 9E936 Throttle Body Gasket 68 — Vacuum Fitting 69 — Camshaft Position Sensor Screw 70 6B288 Camshaft Position Sensor 71 8255 Water Hose Connection Gasket 72 — Water Hose Connection Bolt (3 Req'd) 73 8592 Water Hose Connection 74 8575 Water Thermostat 75 6065 Cylinder Head Bolts 76 6500 Valve Tappet 77 6K512 Valve Tappet Guide Plate 78 6564 Rocker Arm 79 6A528 Rocker Arm Seat 80 6A527 Rocker Arm Bolt (8 Req'd) 81 — Ignition Coil Mounting Bracket Bolt
(3 Req'd) 82 18827 Noise Filter Condenser 83 — Ignition Coil Mounting Bolt (4 Req'd) 84 12259 Spark Plug Wire Set 85 12029 Ignition Coil 86 12043 Ignition Coil Mounting Bracket A — Tighten to 5-12 Nm (4-9 Lb-Ft) B — Tighten to 5-7 Nm (3-5 Lb-Ft) C — Tighten to 21-26 Nm (16-19 Lb-Ft) D — Tighten to 2-10 Nm (1.5-7 Lb-Ft) E — Tighten to 8-13 Nm (6-9 Lb-Ft) F — Tighten to 40-55 Nm (30-41 Lb-Ft) G — Tighten to 16-20 Nm (12-15 Lb-Ft) H — Tighten to 20-30 Nm (15-22 Lb-Ft) I — Tighten to 8-10 Nm (6-8 Lb-Ft) J — Tighten to 8-11 Nm (6-9 Lb-Ft) K — Tighten to 23-30 Nm (17-22 Lb-Ft) L — Tighten to 20-40 Nm (15-30 Lb-Ft) M — Tighten to 4.5-7 Nm (3-5 Lb-Ft) N — Tighten to 18-26 Nm (13-19 Lb-Ft)
Feb 24, 2009 | 1995 Ford Escort
How do make air compressor shut off at your desired air pressure
You compressor has a pilot valve that controls the tank pressure and the speed of the engine. Locate the brass pilot valve, (It has a flip lever that unloads the compressor) you will notice that it has two locking nuts that allow for adjustment when loosened. Loosen the small lock nut and turn the upper-most part of the pilot valve out to reduce pressure, in to increase pressure. Hope this helps, enjoy.
Dec 11, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Air Tools & Compressors Logo
51 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
