Question about Dell Computers & Internet
My computer wont work and it says that it is not plugged in right. So I was looking for a picture of the back of a Dell Dimension 4100 to see how to do it exactly. Can you tell me how to get this.
  • 27 Answers
Here is a link to the PDF version of the setup manual. It will show you how to hook all of the connections up.
Manual
Here is an actual image of the back of a Dell Dimension 4100
Back
Here are more pictures that will help you for reference.
More images
Good Luck. Rate Please.
Posted on Mar 16, 2011
No beeps but lights A B are orange
....and lights C, D are green, and your computer fails to boot up ? (you do not say) (on Dell PCs, which I don't have, the LEDs are usually described as yellow and green. There are four of them on rear of the PC ?).
First go to this webpage:
Product Support
if you are able run the Dell Diagnostics, or if not the ePSA.
Also read this manual - the only one available specifically for Dimension 4100 -
http://downloads.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-4100_Service%20Manual_en-us.pdf especially the section on safety. If you have to open the case remember to properly earth yourself.
To the answer to your question, if the 4600 model has the same codes as the 4100 see the service manual for the Dimension 4600 (or get the corresponding manual for the 4100 by contacting Dell support) look here
http://downloads.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-4600_service%20manual_en-us.pdf
in the Advanced troubleshooting section. It tells you the problem may be with your memory module(s) and it suggests what to try. I favour checking to see if you get correct errors with no memory inserted then with each module in each slot until all 4 combinations have been exhausted. This likely to tell you what is wrong. You may have to replace a memory module, or work with only one module or replace the motherboard.
23.June.2015
Apr 18, 2014 | Dell Dimension 4100 (-JM0TB01) PC Desktop
How to remove cover from dell dimension 4100?
APB1963,
You can click the link below to download the online manual for the Dimension 41000. Within the manual are instructions for opening the computer case.
Dimension 4100 Online User Manual
http://dell.to/16xh0kC
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 05, 2013 | Dell Dimension Computers & Internet
I have a Dell Dimension 4100 and when I try to start the screen is black. It says that there is no signal. What do you think the problem is?
there are two cables whith the monitor/lcd one for the power and the others goes to the computer
the message says that the cable is not attached to the computer properly take it out and refix it
Feb 04, 2011 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Can you assist me with Finding ethernet port on dell demension 4100
It should be at the back of the system. Look for RJ-45 jack. If its not there then your computer does not have one.
May 19, 2010 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Dell dimension 4100 with microsoft pro 2000 with win 98 pc wont start keep giving messgae Invalid Boor Diskette Insert BOOT diskette A:
please try to go to the Bios by following the key shows on startup of your computer and go to boot option and set boot order to the first as hard disk
and remove the floopy from being the first boot
cheers
Apr 18, 2010 | Dell Dimension 2300 PC Desktop
I have a dimension 4100, and only have 512 in ram because it only has 2 slots, is there any way to use a bigger stick to increase ram?
Yes, if only one slot is being used you can install another 512 MB of ram which will give you 1024 MB or 1GB. If both slots have 256 MB in each one then you will need to just buy a 1GB strip of Ram. Go to the link I am posting and let them scan your computer. They will tell you exactly what you can install and the price. This is a site I use all the time and it is reputable and safe with good prices. This will require a download of the scanning tool which is safe. Allow the download. http://www.crucial.com/
Nov 05, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
No video
you can try to hook up everything back up and then take out the video card and clean the place that it llides into and the card itsself and reinsert it and see what happnes but please make real sure that u connect everything back just like it was cause if there are cablkes that are switched there will be problems
Aug 19, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Setting it up
Hi
Dell Dimension 4100 uses an add-in AGP Video card.
The Video Port is labeled "5" in the illustration below;
System Reference - http://support.dell.com/support/edocs/systems/dzuul/techovu.htm
Mike
May 15, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Problems with Dell Dimension 4100 PC Desktop
maybe your dell dimension needs an audio driver. you can find drivers here by inputing the model or the service tag number. service tag found at the back of your PC.
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn&SvcTag=&SysID=DJ_DIGITAL_MP
Just follow instruction if your were in the site.
if this not solve;
try another audio card.
Jan 02, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Case upgrade for Dell Dimension 4100
The easiest thing to do it is look at your motherboard and make a note of the manufacturer and model/version number, as Dell don't make their own boards. Go to the manufacturers web site and search for the manual probably in PDF format and download it and look for the relevent power button connections.
Oct 11, 2006 | Dell (2336V) Motherboard
Computers & Internet Logo
55 people viewed this question
Alun Cox
