Question about Janome Sewing Machines
I have a tension problem with my Janome SR2000 the stiches are tight and small on the bottom and top,How can I fix this.
  • 26 Answers
SOURCE: bottom tension to tight
There's hardly any way to significantly adjust the bottom, or bobbin tension. There's just a small, flat spring attached to the side of the bobbin case, under which the thread runs. There's adjustment there. You need to adjust the top thread tension via the small thumbscrew that's against the plates on the top thread tension discs. Increase or decrease tension there until top and bottom threads are equally centered between layers of material.
You can adjust presser foot tension with the knurled nut at the top of the machine. I never had the kind of problem you mention though. I set my machine at about 6 stitches per inch or a little more (max is 5, recommended), and presser foot tension is only heavy enough to pull a single layer of material through.
Hope this helps.
Posted on Jul 13, 2009
  • 26 Answers
SOURCE: my top stich thread loops and my bottom thread is
reset the top thread tension take-up spring - not the discs, the small, U shaped spring the thread goes through after the tension discs. Loosen the screw and turn the assembly down to add more tension to the spring.
Posted on Aug 14, 2009
  • 3 Answers
SOURCE: How do I adjust tension top thread too tight bottom
The bottom tension is too loose. If your bobbin is in a case there is a little screw on the side that will tighten the plates and increase the tension. Test your thread coming out of the case as you slowly make adjustments to the screw. A slight bit of resistance is what you want. If your sewing still puckers you may have to loosen the tension on the top. Sew on a scrap and go toward the smaller numbers to loosen the top tension until the stitches meet between the two layers of fabric.
Posted on Dec 21, 2009
  • 255 Answers
SOURCE: loose stich on bottom of fabric
Hi. The problem is that your upper tension is too loose. It needs to be tighter in order to pull the bobbin thread up.
Robbie
Posted on Apr 17, 2010
Testimonial: "This was only helpful in that is did not say HOW to fix the upper tention, being a nofice I don't know that, please help. Thanks Louis"
SOURCE: tension on top side of stiching is too tight
usually a tension of 3 or 4 is good
rethread the machine to make sure the thread is not caught anywhere
Posted on Nov 23, 2010
How can I fix the top stich
I like to adjust with 2 colors, then you know which is from the spool, and which one is from the bobbin.
Most bobbin shuttles have a small screw to adjust the tension.
It sounds like your upper thread is adjusted too tight, but only if the loops around it (from the bottom thread) are tight and small. If those loops around the top thread are loose, then you need to tighten the shuttle screw. ;)
I notice this happens to me if I change thread types, also if I sew different thickness of cloth on the same settings. I tend to adjust until the point of breaking thread, then loosen the top a teeny bit.
Sep 06, 2014 | Sewing Machines
Thread broke on bottom looper the first time out of box i had to try and thread and the tension was still tight The bottom threads were not stiching
I'm going to assume here you're talking about a serger. Unthread the lower looper and the eyes of the needle. Set the lower looper tension to 0. Rethread the lower looper, then the needle eyes. Then reset the lower looper tension (try about half a number lower) and see if it chains. If it won't chain, try replacing the needles.
Mar 17, 2014 | Janome Sewing Machines
The top stich is loose on my Janome Harmony 8100, I have cleaned and changed bobbins, but nothing seems to help.
Ok, Let's understand exactly what is going on. You said. "the top stitch is loose." So that we are clear....do you mean that you are getting loops on top of the seam? Or do you mean that you are getting wiggly stitches on top and small loops on the bottom of the seam? It's important to know... Because loops underneath means the top tension isn't right. Maybe you didn't thread with the presser foot in the UP position... or your tension is dialed too low.
Now, if you are getting loops on top of the seam... that means the top tension is too tight. Loosen the top tension. Make sure your bobbin is inserted correctly. If loosening top tension isn't enough, you may have to tighten the tension screw on the bobbin case/ or bobbin carrier.
Feb 25, 2013 | Janome Memory Craft 9000 Computerized...
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
Bottom stich from bobbin is bunching up.
Make sure you have the bobbin in the correct way round and make sure you have gone completely through the tension discs when threading the machine, make sure the top tension is set properly.
Nov 01, 2009 | Janome Memory Craft 9000 Computerized...
My bobbin wont feed through
take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Sep 24, 2009 | White Sewing 1418 Mechanical Sewing...
Bottom tension to tight
I found that sewing this type of fabric you should not have any pressure on the presser foot. and the top tension should be looser but note the tension before you adjust. and remember to make sure the needle is the right size for the fabric. and since wer are not to change the bottom tension because it always right?? then you may have to make the seam stitch longer good luck
Feb 23, 2009 | Consew 226R-1
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Sewing Machines Logo
59 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
