Question about Panasonic Heating & Cooling
Panasonic ceiling cassette air con fault E1. dont know model number check keeps comng up on display panel
4 Suggested Answers
SOURCE: Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Posted on Dec 08, 2008
  • 99 Answers
SOURCE: I have water leaking through the ceiling
Hi; I have encountered several problems when it comes down to water(condensate) draining correctly.. Here are a few things to look at. First and foremost never blow a drain line from the top or through the bottom. the reason being all the muck will travel back into the drain pan. Why not purchase a tool that will **** from the bottom of the drain line therefore not putting strenous pressure on pipe joints that might have missed the gluing process. Also You can purchase this tube venturi device from a local ac supply house. If You have a level indicator put it across the air handler (side to side,front to back) check that there is level or a slight lean towards the drain line. If You are going to **** the line make sure all tees with a tube sticking up are temporarly caped up at the air handler. Now another problem can be a clogged air filter.This will pull on the drain line water for air thus keeping the unit from draining until the unit turns off. Then there is the ocasional drain pan that will crack prematurely. After You have reserched all above potential problems and have drainage purchase some algae tabs to put directly into the drain pan(removing the cover with the tstat in the off position).One more thing to consider is the drain line sweating due to a full line of cold water wanting to drain.
Go out side after problem solved and put 2, 90 degree elbows on the end with a 6 inch piece of pvc pointing up and fill with water. What You are doing is giving the drain line a resistence point from the fan motor it wont be able to **** that water back up thus causing a steady drain of water YEA...alpharome416
Posted on Feb 22, 2010
flatech
  • 111 Answers
SOURCE: I've got an error 1 message on my Kelvinator air
Here is a Toll free number to Kelvinator. Good Luck!
Technical Support Center - U.S.A. 1 (866) 738-1641
Monday - Friday
8:00 am - 6:00 pm EST
Posted on Nov 13, 2009
What is e1
Hi Alvin is it a portable air con, Split air con, What brand + model number.......
Mar 30, 2016 | Heating & Cooling
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
Panasonic ac unit keeps coming up with a fault.... the error code is F90 air con is 5kw
dont no the code but if you call pana and tell them the code they should no what it is. not always usefull as they can give a general response but worth a try. then post the answer.
Jan 20, 2013 | Panasonic Heating & Cooling
Remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Sep 19, 2009 | Heating & Cooling
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
Lg dishwasher model LD - 14AT2
E1 is usually a very common fault of the wash motor not working.
The impeller breaks away from the motor shaft and doesn't spin, therefore, it doesn't pump water.
There is a sensor that activates with low pump pressure, which shuts down the machine and displays the error, E1.
The only other causes (that I'm aware of) are leaking water supply hoses, or pump blockage, but the motor fault is by far the most common.
Hope this helps.
Mar 18, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Heating & Cooling Logo
99 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
