Question about Kenmore Washing Machines
Water is leaking out of front bottom washer - Kenmore Washing Machines
  • 5,911 Answers
A leaking washer can have several causes. In order to be able to accurately determine where the leak may be coming from, you will need to remove the exterior washer case to get a full view of all the interior washer components. The following link explains how to perform this procedure and what to inspect for:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
From the symptoms you have described, it sounds like you may have a leaking drain pump. These pumps are not serviceable, and if leaking, they must be replaced. The following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The average price for a pump is about $35.
NOTE: Kenmore washers are manufactured by Whirlpool, so these instructions do apply.
NOTE: If this is a FRONT loading Kenmore, the following link will give you some guidance on how to inspect for leaks and what to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader If you have any questions about any of these procedures, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Mar 17, 2011
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water leak at front of washer
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Washing Machines Logo
49 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
