Question about Cameras
The lever to zoom in and out wont work. we have reset factory settings and it still wont work. tried 3 different sets of batteries and even new memory cards. still othing. this camera is only 4 months old.
JoeO700
  • 80 Answers
SOURCE: Canon A85 has stopped shooting
The A85 has had problems with the operations deck assy which contains the primary controls that the customer uses to operate the camera. If this is the problem, the part is approx. $60 from Canon, I am not sure what they charge for labor to replace the bad component. Good Luck to you. Joe Weibel customelectronics.org
Posted on Feb 16, 2007
  • 3 Answers
SOURCE: Shuts down while using the zoom lever
see this thread :
http://www.fixya.com/support/t225803-canon_powershot_s3_switches_off_when
Posted on Mar 28, 2008
  • 13 Answers
SOURCE: Fuji FinePix S700 Problem
Try to put it on super macro and see if this will reset the zoom function.
Also try to switch between the settings that allow the digital zoom, as compaired to those settings that only allow optical zoom.
If these do not work, you may have a lens that has been dropped, or is stuck, and may need to be serviced. I have the S700, and have never seen this error before> good luck.
Posted on Jun 13, 2008
SOURCE: Nikon Coolpix S710 must set date and time everytime.
add me in i have the same problem (time and date reset every time you turn off the unit) plus s710 hangs when on view mode... is this something to do with the firmware (mine is ver.1.1)........ please help..... its very annoying....
Posted on Jan 02, 2010
SOURCE: my dmc Lz8 continually zooms in and out and then goes blank.
Same problem, lens cycles in and out then says 'turn off and back on again'. I fixed by grabbing the lens as is comes out and pulling and wiggling to help it to it's full out position. Don't force it, but help it reach full out. It took a couple of times, but now seems ok. Suspect a grain of sand or dust was preventing it from reaching full extend.
Posted on Jun 27, 2010
How to set camera back to factory settings
Use the Setup Menu option RESET.
This resets all the settings except DATE/TIME, TIME DIFFERENCE, BACKGROUND COLOR, BATTERY TYPE and VIDEO SYSTEM
to default values.
A confirmation dialog will be displayed, press the selector up or down to highlight OK and press MENU/OK
Aug 11, 2014 | FujiFilm FinePix S2940 14MP Digital Camera...
New batteries but wont turn on
Try the following:
1. Ensure the batteries are indeed, charged. Sometimes even new ones are bad.
2. Ensure battery polarity is observed when loading batteries.
3. Make sure the flash ON/OFF switch is not loose or damaged.
4. With the flash mounted on your camera and the power switch to ON, try resetting the camera to factory default settings. This MIGHT clear any errors and allow the flash to work.
Oct 10, 2013 | Canon Speedlite 550EX TTL Flash
Tried a different battery and still wont turn on, has not been dropped, is there a way to reset from factory like a phone or it that it for the camera
If it won't turn on then you cannot set it back to factory settings. The W330 is a fairly new model and should still be under warranty (1 year) so try contacting Sony support for a local repair facility.
Feb 03, 2011 | Sony Cybershot W330 Digital Camera
When I turn on my camera it says entering favorites?
have you tried a factory reset? or try doing a firmware update, could be the firmwares got corrupted, or have you done a firmware update and it did not update properly ?
Mar 02, 2010 | Kodak Easyshare Z812-IS Digital Zoom...
K850i,contrct from 3 ended got phone unlocked put in new sim to start new contrct, every thing works but txt . wont send or recieve ???? new network says my phone is bust tried new sim in other phone and...
This is a unusual symptom in a mobile phone, you should try a hard reset and a factory reset.
1. Hard reset, take the battery out for 30mins and try again
2. Factory reset will reset your phone to factory default settings to so this just go in the settings option and then find the reset option make sure you choose the total reset option
Hope this helps
Muzzi_123
Nov 14, 2009 | Sony Ericsson K800i Cellular Phone
I have a sony cybershot dsc-f707 Icant zoom in or out only after I take a picture. I also wanted to know if I need to charge the lense to zoom?
Option 1:
Reset the Camera and check if it helps to resolve the issue.(Resetting the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
The RESET button is located inside the battery/ Memory Stick cover. The Camera should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Use a fully charged Battery in the Camera so that the Zoom function work normally.
Aug 27, 2009 | Sony Cameras
Model 51f59a hd widescreen aspect settings dont take and picture too big
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
Apr 25, 2008 | Hitachi 51F500 51" Rear Projection...
Same problem
your batteries are dead.
Oct 27, 2007 | Samsung Digimax S500 Digital Camera
Camera has locked down!!!
resetting may help solving the problem. in order to reset your Olympus Digital Camera, please follow the instructions provided below: 1. Remove all cards, cables, etc. 2. Remove the lens cap or slide open the lens cover and turn the camera "ON" in any of the record modes. Then remove the batteries. 3. let the camera sit for approx. 5 to 10 minutes 4. Re-insert the card and a fresh set of batteries or an AC adapter 5. Test the camera I hope this will solve your problem.
Mar 29, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
