Question about Whirlpool Dishwashers
Bottom seal at the base of the door is leaking badly
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Mar 18, 2011
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: dishwasher door leak
Hi
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
Posted on Feb 10, 2009
SOURCE: door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Posted on Jul 02, 2009
WHEN DOOR CLOSED AND RUNNING WATER LEAKS FROM BOTTOM OF DOOR, UINT IS ABOUT SEVEN YEARS OLD, USED TWICE A WEEK. THANK YOU.
HI, seen this a lot when i did apartment maintenance, try cleaning the seal at bottom soap and gime can build up and causing a bad seal,if that does not work you will need to replace door seal.
Mar 05, 2011 | Dishwashers
Our Dishwasher is leaking out the sides bottom sides.
The door of every dishwasher has a compressive rubber seal. When you close the door, it compresses to prevent the water lealking out. Yours has perished and a split is allowing the water to leak out. You just need to write down the model and serial number (for good measure) and contact the makers parts supplier. Buy the new seal and install. If you are not confident to try this yourself, a repairman can be booked to do it for you, but it's not difficult, the seal slides into a guide track (at the top internal centre of the door) - the track continues down to the base of the door, across the base, up the other side and when installing, you simply inch it into the guide around the door perimeter until it joins again at the top.
A bit like putting a belt through belt loops...
Apr 07, 2010 | Weber Genesis Silver C Premium Grill
My refrigerator accumulates moisture that show up in the bottom tray. What can cause that and where could it be coming from? I have checked the filter and it does not show anyleaks
check the door seals,if your getting warm air in the cold compartments it will sweat,and condense and end up in the bottom area of the refrigerator,you can clean the seals with an alcohol bases solution to make them seal better again also clean door area where seal contacts,or the defrost drain pan and drain hose could be leaking
Jan 08, 2010 | Refrigerators
Water is collecting at the base of the dishwasher after the washing cycle
Either the door seal is bad or the seal for the pump is bad or a possible leak of the drain hose (not probable)..
Check the door seal by taping some dry paper right below the door and see if it gets wet BEFORE opening the door.
Sep 09, 2009 | Whirlpool Dishwashers
Leaking dishwasher
HI, i would inspect the door seal. make sure there isn't any foreign objects that are getting stuck in between the door seal and tub housing. if the seal is clear of any objects(small objects), this will confirm door seal failuer.
simply replace the bad door seal in this case.
Jun 16, 2009 | Kenmore Dishwashers
Dishwasher door leak
at the bottom of the door is going to be the door seal starting to go bad. replace the seal
Nov 24, 2008 | Dishwashers
Leak at Bottom of Door
ya that sealing would have gone bad try to attach a rubber fitting with it tat will stop flow of soap suds
Jul 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
WATER COMING OUT FROM DOOR AND DRAWER
On this washer  the seal was replaced ?Did it stop leaking after the seal was put in ? Front load hatch on this is in front area located on the bottom(base).Remove the front  to gain access and you can now reach the pump and  look for any blockage.After  you have found and removed the blockage,run the washer again and if any water leaks remain call your local  servicer .You may have a bad front boot (seal) or its just loosened and it need to be re- tightened.Any water leak should be repaired ASAP so you dont have even more damage to the machine and your home.If the repairman cant stop the leak on his first visit than have the Boot replaced on his second visit.
May 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
