Question about Sport & Outdoor - Others
I have an autohelm 1000 with a broken gear that the drive belt runs on. Where can I purchase replacement gears for it?
Parts no longer available for older units. But im willing to buy broken autohelms for parts. seawolf-vital@live.com
Posted on Nov 26, 2012
Mowing and made a small bang just stopped motor running ok but wont drive any suggestions thanks
check for a broken shear pin in the drive gear
check for broken drive shaft or stripped gears
Oct 01, 2016 | Garden
Whyj won't my craftsman LT 1000 move when in gear
sounds like the transmission is disengaged. on the back under the gas tank, you will find a vertical metal plate. on the top right of that plate there is a silver rod sticking through it with a little clip on it. the rod has 2 holes, move the clip to the other hole. if that doesn't correct the problem then the transmission belt may have broken or streatched out and needs relpacement.
Apr 28, 2014 | Garden
Spin scrub will not spin
If its belt driven, the belt had dislodged or broken off completely. If gear driven, the gear teeth had broken, so the gears needs replacement. If you purchased less than a year ago, find the store receipt or look up the purchase history on your bank/ credit card invoice archive and if it shows the product name and model number, then that's sufficient proof of purchase. Some retail stores like Walmart can printout a duplicate receipt if you know the exact date, time of purchase, and which register processed the transaction. When you have proof of purchase receipt, contact the manufacturer for address to return product to file 1-year warranty claim.
Nov 19, 2013 | FH50150 Carpet Cleaner, Power Scrub Deluxe
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Heritage Softail 87 on my way home I lost all gears, clutch feels fine, and I can feel it select gears but still no engagement of the gears, the bike also runs fine but no neutral light. Cheers...
Put the bike in gear with the engine not running. Try to push the bike. If the bike rolls freely, the final drive belt is broken. Check the tension on the belt. The only other thing that I can think of is the final drive belt front pulley has stripped out. The early belt drive bikes, the front belt drive pulley was very thin in the area where the splines were cut for the final drive gear. In 1994, Harley can out with an improved front pulley and offered a retrofit kit to replace the earlier models. When the front pulley strips the splines out, it will not drive the rear drive belt. The final drive gear simply turns inside the center bore of the pulley.
To change the belt on your Softail, you'll have to pull the outer primary cover, the entire primary drive mechanism, the inner primary, the starter, the exhaust system (to get the starter off), the rear wheel, and the swing arm. If the pulley is bad but the belt is good, you do not have to pull the rear wheel and the swingarm.
Good Luck
Steve
Apr 21, 2011 | Harley Davidson FLSTC Heritage Softail...
1991 HARLEY DAVIDSON SOFT TAIL NO SPARK FROM IGNITION VALVES NOT OPENING OR CLOSING MOTOR DOES TURN OVER
Using all caps makes it sound like you"re shouting...
It sounds like you have either lost your camshaft drive (broken timing chain, or belt, or broken gear(s)), or your camshaft has broken right where the driven end is. In any event, your cam is not turning.
I worked on a Ford van once with gear to gear drive for the cam, but the cam gear was a fiber/resin gear (for quiet running). There was a crank-shaft-gear shaped scoop carved out of the cam gear. Had I not seen that, I would have thought gear-to-gear drives can never fail. Apparently not.
Jun 15, 2010 | 2004 Harley Davidson FXSTS - FXSTSI...
Autohelm 4000 ST fails to drive
CHECK INSIDE
BELT CONDITION
RUNNER BROKEN OFF
CHECK OUTSIDE
CLUTCH LEVER PIN BROKEN ,CLUCH LEVER OUT OF POSITION
BELT TENSION ADJUSTMENT WRONG (REMOVE SMALL COVER PLATE (+- 10mm Dia)ON REAR OF BACKPLATE ,LOOSE SPECIAL NUT ADJUST WITH ALLEN ,TORQUE NUT,PUT COVER BACK
Feb 19, 2010 | Raymarine St 4000 Wheel Drive E12093
CD will not eject - it plays fine - but the tray will not open
If the tray mechanism is belt driven, the belt may have become loose or is broken and needs to be replaced (usually the belts are of a standard measure and can be purchased in electronic stores or via internet), but if there are only gears to drive the tray mechanism then it could be broken teeth on a gear wheel, faulty drive motor or faulty motor driver electronics.
Hope you can fix it.
Regards,
Triarcuate
Oct 17, 2009 | Denon DN-C615 CD Player
Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Jan 19, 2009 | Intimus 385 se Shredder
Sport & Outdoor - Others Logo
167 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
