Question about Kitchen Ranges
I have a carrier unit fy4anb060 i took off the filter to replace it buton trash day my husband thru it out thinkin i had already replaced it can you help me find out the filter i need to use on this unit.
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
boscia
  • 163 Answers
SOURCE: cannot replace rope the
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on Nov 29, 2008
pierre1811
  • 144 Answers
SOURCE: Need help Locating replacement parts online
You shouldn't have to get the OEM or manufacturers motor. Get the info. off of the old motor like volts, RPM and HP(horsepower) or just bring the motor to an appliance parts store. They should be able to match it up. Make sure that you get a new capacitor for it too. The cap. rating will be something like 5mfd on the motor.
Posted on Mar 13, 2009
  • 127 Answers
SOURCE: I have 2 Carrier units, one for downstairs and
You may or may not have to go into attic, depends if an additional filter system is installed. May have filter grille's install in ceiling, or wall. If no filter's on the interior, then there should be in the furnance or filter rack in the attic. Filters should be used for no more than 3 months without changing or cleaning if washable.
Posted on Aug 27, 2011
BAMOUT
  • 2478 Answers
SOURCE: kawasaki engine dies after running 20-30 minutes
Check fuel cap vent.
Posted on Oct 17, 2012
How do I replace a filter on my 1975 Carrier central A/C?
THE FILTER IS THE AIR FILTER . IN THE RETURN AIR GRILL EITHER IN FLOOR OR IN THE WALL / SOME ARE INSTALLED IN THE UNIT IN THE AIR HANDLER COULD BE INSIDE A CLOSET OR ATTIC OR UNDER FLOOR / FIND AND CHANGE IT . IT WILL BE WHERE THE AIR IS PULLED INTO UNIT ON RETURN SIDE AS I SAID SOME IN FLOOR GRILLS , SOME IN WALL GRILLS . SOME IN CEILING GRILLS . JUST TAKE OUT AND GOTO LOWES OR hd GET SAME SIZE AND REPLACE
Aug 18, 2014 | Heating & Cooling
Replacement air filter
I'll let you know if the parts are available..
Jun 02, 2008 | Carrier XCA141D Air Conditioner
Get code 13 even after a reset on Carrier 58mxa060
Code 33 to a 13 is a limit switch open. Check the inducer motor to make sure it is spinning. Check all venting for obstruction and debris. Check the air filter. Make sure all condensation is draining away.
Dec 26, 2009 | Heating & Cooling
Air not coming thru ducts
Very possible the long bladed fan is stuck. Possibly when filters were cleaned and replaced, a part is touching the blade. Remov filters and turn blade by hand. Does it move freely.(make sure unit is off when turning the blade.
Sep 20, 2009 | Carrier 38CKC036 Air Conditioner
Fuel Pump, Fuel Filter and wiring
Unit is replaced as unit. Fuel filter is located by L/R wheel
Apr 01, 2009 | 1994 Cadillac Fleetwood
2004 r1 it won't start need help
Id Smack The Started With A Hammer Cause That Would Be Your Clicking Sound. But Yeah Id Start With The Fuses Other Wise.
Jan 12, 2009 | 2005 Yamaha YZF-R1
Central air conditioning system
Check the filter(s). Dirty filters is the primary cause for such failures. Secondly check the thermostat and make sure that it is not turned way too low. Anything above 70 is safe from causing freezing on the unit. If the unit is already frozen then turn the unit off until it is totally thawed and then retry.
Jun 30, 2008 | Heating & Cooling
LG DLE5977 Electric Dryer
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee. My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007 Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
Jun 11, 2008 | LG DLE5977 Electric Dryer
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
