Question about AEG 24 in. Favorit 80860iW Built-in Dishwasher
My dishwasher AEG FAVORIT 50860i shows a fault code 1h every time I try to start a program.
  • 54 Answers
SOURCE: AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Posted on Feb 14, 2008
heralddriver
SOURCE: DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Posted on Oct 25, 2008
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
Posted on Nov 11, 2008
SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Posted on Mar 05, 2009
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
Type 60870 not heating water!Have a wiring giagram for trouble shooting?
Could be: faulty power board (completly or only relay for heating element), faulty wiring between heating element and power board, faulty heating element (interruption, short circuit or current leakage,on some heaters faulty thermal protection).
Depending on the model, the display shows the i60 fault code or the LED end of the program will flash 6 times (only model without display).
Dado
Mar 17, 2015 | AEG 24 in. Favorit 60870M Free-standing...
I have a AEG Favorit 65011 VI (dishwasher) which stops in the middle of a programm an shows error ",60" that is not mentioned in the Users Manual. Can you please help me?
The temperature must increase by a certain amount at each step.
If there is no temperature increase during three minutes, the electronics will generate "Heating Time Out" or fault code i60.
In this case program will continue to the end without heating and the washing result will probably be unsatisfactory.
Could be: Heating element faulty; intervention of safety
thermostats (open); faulty wiring; NTC sensor (poor
thermal contact); insufficient water circulating in the
tub; washing faulty pump (impeller stripped); circuit
board faulty.
Dado
Mar 10, 2015 | AEG Dishwashers
What does error code 155 mean
This is not error code. If a fault occurs on your device it will be displayed in hexadecimal code for example:
Newer models: i10, i20, i30 ....... i90, iA0,.............iF0
Older models: A0, A1 ........ A9, AA, Ab,............. Af
or C0, C1 ........ C9, CA, Cb,........... Cf
Because that I believe that the digit number "155" that you see on the display means the duration time (minutes) of selected program. Also see in user manual how to cancel selected program and choose new one.
Dado
Nov 04, 2014 | AEG 23 in. Favorit 50750Vi Built-in...
AEG Favorit 60870 Dishwasher not starting
Matthew, in most cases when a circuit board repeats the same action over and over, there was a short and loss of communication with associated controllers. Obviously you have power to the control unit, so that means the instructions from the controller to the solenoids is lacking. You are correct in assuming the board needs replacement, however you must determine is the cost for replacement is worth the time and effort. An old machine means one repair after the other. If its relatively new; then it may be worth it.
Mar 10, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Message -spray arm blocked
Check water pump inside the machine for its full speed.If the speed is low check the capcitor and replace.
May 27, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Aeg 60800 dishwasher showing c2 on panel,water still in bottom of dishwasher. will not start.
from other forum
Not pumping or pumping too slow. Check for blockages in pipework, filter and pump. If all clear, replace pump.
Curing the fault on these machines doesn't always get rid of the error code though. Some faults are locked in.
If you find this, post back and I'll try to help.
Mar 11, 2010 | AEG 24 in. Favorit 60800 Free-standing...
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Mar 27, 2008 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorit dishwasher fault
check time delay function - press til '0' appears or repeatedly til all time delaying diodes do not light
Feb 20, 2008 | AEG 23 in. Favorit 50750Vi Built-in...
Open Questions:
Hi, I have read all posts for fixing AEG Dishwasher not heating water problem. Most answers were about PCB heater relay. I have a Favorit 80860iW sensorlogic turbo, (turbo is car?) [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800026-1.jpg[/IMG] and i treat it as a lady. Always best materials in, and dishes cleaned before input. Now, I removed door panel, also 2 PCBs inside, but couldn't find any relay to re-solder it. I am posting some photos here, if anyone please see any problem in my PCBs, or the famous relay, just send me an answer where to solder. 1. when removed fascia. [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800038.jpg[/IMG] 2. back side of fascia [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800047.jpg[/IMG] 3. PCBs removed [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800039.jpg[/IMG] 4. PCB with red display panel [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800043.jpg[/IMG][IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800040.jpg[/IMG] 5. PCB with power button [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800042.jpg[/IMG] [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800041.jpg[/IMG] 6. PCB on the bottom of dishwasher [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800051.jpg[/IMG] [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800055.jpg[/IMG] I am disappointed, its a 2000 expensive buy, told me it would last, and i fixed it 5 times already. The dishwasher program is working normal, it just won't heat no more. I replaced today the bottom sensor, which fixed this problem 2 times in the past, but now, no luck with new part, it don't heat. 7. sensor replaced [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800049.jpg[/IMG] 8. where sensor goes in [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800052.jpg[/IMG] thanks for your time.
Feb 05, 2011 | AEG 24 in. Favorit 80860iW Built-in...
See all AEG 24 in. Favorit 80860iW Built-in Dishwasher Questions
AEG 24 in. Favorit 80860iW Built-in Dishwasher Logo
381 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Kolbrun...
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
