Question about Garmin nuvi 200W GPS Receiver
My Garmin Nuvi 200 wont turn back on
I charged my Garmin nuvi 200 in my truck for a couple hours. it was working all day. and when i plugged it in it said "battery charging" so i know it was working but when i took it out i couldnt get it to turn back on. iv tried holding the slide button for several seconds. what can i do? i bought it from my buddy and it was brand new. all that came with it was the car charger. please help me
  • 5 more comments
  • dlwofford1 Aug 03, 2008
    Charged mine up used it for about 45 minutes, ate dinner came out and it would not turn on or charge... just dead. I only have to drive 2400 miles in 2 days, I would like to be able to use it!
  • Anonymous Sep 06, 2008
    My garmin nuvi 200 is not coming on
  • gmorper Dec 01, 2008
    My son just moved to Seattle and his Garmin Nuvi 300 worked for a day and now it won't start. He said he got his oil changed, and it didn't work when he got back in his car. He really needs this to get around to find a job. HELP
    Terry
  • bhiten Dec 21, 2008
    was using a new garmin nuvi 200w and it went black thought it was dead but wont charge or come on even after reset!
  • ajm377 Dec 25, 2008
    My Garmin nuvi 200 will not turn on. I even tried unplugging it and resetting it then plugging it back in! Please some one help me
  • shamimcoulte Dec 26, 2008
    My garmin worked only twice in the last year since I purchased it. Is there any customer support for Garmin? Can I return this item?
  • steamypon Dec 30, 2008
    I had the same trouble. I had it plugged in for several hours the second to the last time I used it which should have left it with a full charge. The last time I used it, which was one day later, it showed it had 3/4 charge when it should have been full. The unit worked for a while later, then went dead presumably after the battery went dead, in spite of being plugged in during this last time of using it. It was as if the unit was not plugged in, even though it was. I was unable to get it to work after using my fingernail to press the reset button. After reading the postings on this site and recommended fixes, I pressed the button again this time with a pointed object, with the unit unplugged and this time it worked fine after I plugged it back in. I suspect there might have been a power surge from starting and stopping the vehicle with the unit plugged in that triped a safety circuit built into the unit and thereby needed to be reset. I suggest making sure you are fully depressing the reset button before giving up. I was being cautious not to damage the lable and not resetting the unit. Press it firmly untill you feel it bottom out and the lable should still be fine. Good luck to all and thanks to all who help others on this site!
Our Garmin didn't turn on. We unplugged it, pushed the reset button on the bottom and then plugged it in again and it WORKED
Posted on Dec 01, 2008
Tried everything subscribed on many of the GPS sites, including the reset button. It was only THIS thread which describes the MANNER in which the reset button must be pushed, that does the trick.
Your finger is NOT ENOUGH to fully depress the reset button. I used the corner of the small end of the USB connector to depress it AFTER disconnecting it from the unit. Nothing happenend when I released the reset button, but when I plugged it back into the laptop via the USB cable, it turned on automatically.
Posted on Dec 21, 2009
Omg, i didnt even realize there was a rest button until i read this forum, i used a paper clip AND IT WORKED!!! THANK GOD, i thought that i was going to be left with another brick of technology.  Last wk, my WII console turned into a brick! Thanks for all the posts, it helped!
Posted on Jan 16, 2010
I have the garmin nuvi 200. It won't turn on. I disconnected it from the external power source, then pressed the reset button, but itstill won't come on. I didn't throw it up against the wall yet but I'm getting close.
Posted on Nov 26, 2009
AT THE BACK WHERE THE SERIAL NUMBERS ARE..LIFT THE STICKER AND YOU WILL SEE THE HARD RESET BUTTON..PUSH IT WITH A POINTED OBJECT GENTLY,,,,THEN SEE IF TURNS BACK ON...GOOD DAY.
Posted on Sep 08, 2017
Did you try resetting the unit?
1. Disconnect the nuvi from external power
2. Press the RESET button on the bottom of the unit
3. Connect the nuvi to a power source
Posted on Aug 24, 2008
Why won't my Garmin Nuvi 780 charge?
A couple part answer here. The USB pin out for the Garmin is strange. If it goes into PC mode, then the cable is got the wrong pin out for the unit. Try different cables until one works.
If you can get a full charge on the unit and the battery does not provide at least an hour + of battery use, then the battery needs to be replaced. Amazon sells replacement battery kits with instructions. You just have to make sure you order the right one.
Sep 18, 2017 | Garmin nuvi 780 GPS
Not turning on
My unit was totally dead. I just kept it plugged into my computer for about 12 hours. I downloaded the newest software from Garmin. When I unplugged it from my computer, the battery seemed to drain quick, but once I plugged it into the card adapter in the car... everything seems to be running great now.
Oct 09, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
My Garmin doesn't seem to know where it is.
Give a full 12 hour charge. For the location, go into the main menu and set your location for whereever you want. It must have clear view of the sky to work. It should be on the windshield or dash, in a vertical position.
Jul 11, 2009 | Garmin nuvi 200W GPS Receiver
Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Mar 09, 2009 | Garmin nuvi 200W GPS
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
New Garmin 260 W won't do anything when plugged in.
Your PC may not be able to charge it. If it does it's only a trickle charge. May take a day or two
The Garmin cigarette lighter charger take 4 hours.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Not knowing when my nuvi 250 is fully charged
if the greens bars on the upper right indicates fully charged
Nov 29, 2008 | Garmin nuvi 250 GPS Receiver
First time use / battery charge
The Nuvi units are short on battery life and therefore Garmin has given you a connector other then USB to power your unit while in a car. You need to carry that. It's just a design flaw. If you try to rely on the battery of your Garmin Nuvi, you have less than 2 hours even on a full charge. And carrying the USB adapter which plugs into the cigarette lighter socket won't allow your unit to run while charging. so you need to take the adapter charger bracket that comes with the unit if you need it for longer trips.
Jul 10, 2008 | Garmin nuvi 200W GPS Receiver
I have a nuvi 200 that wont run when it is hooked up to a power supply
The Nuvi 200 only has a 5 hour battery. Once charged, it can be removed from the charger, but the battery will only last 5 hours. Can you plug it into the car charger and navigate while charging BEFORE the battery dies? If so, and you don't have to remove the charger, you can leave the unit plugged in while you navigate without damage to the unit.
Feb 09, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
8,393 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
