Question about Saniflo & Saniplus& Macerator Pump
Smell coming from tolit area - Saniflo & Saniplus& Macerator Pump
1) If you have ordinary tank-and-bowl toilet, add a tank bowl freshener in the tank.
http://http.cdnlayer.com/ec1images/120/products/1/1225705_042707i.jpg
2) Check bottom of toilet to see if there is signs of leakage. Reset toilet on new wax ring.
3) Add a comment with photo of your problem so I can see it:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 16, 2011
    Problem Solver:
  • 10 Answers
The problem with the smell is that the macerator air switch manufactured by Lafoo has a diaphragm in it that tends to sag with time. The switch is mounted vertically instead of horizontally on the circuit board, which is the preferred method of operation. Huge mistake by Saniflo. This prevents the macerator from switching on properly and the unit tends to fill up to high causing the smell. The Lafoo air switch is 5.5mbar and actually has a built in adjustment dial that can be seen when one removes it from the circuit board. The solution (besides putting in a 3.5mbar Lafoo switch) is to unsolder the original switch, solder two 2" pigtails onto the switch and soldier the pigtails back onto the board. This will give you enough room to have the switch hang horizontally and allow gravity to help assist in triggering the diaphragm in the switch. Also, you will also now have the benefit of being able to adjust the sensitivity of the switch if need be depending on the atmospheric pressure where you live. The pressure side (air tube) should be on the top and not the bottom. After you make this modification, your Saniflow will work better than new and the smells will immediately dissapear. The switch will now trigger every time your flush the toilet or when the water level in the unit reaches the proper height. An enzyme type cleaner (used in RV's) will help descale any sludge in the unit but the main issue is with the air switch and how it is mounted. If you need pics of how the unit should look after it is modified, e-mail me at mrizzo@liquecolor.com My wife now has her own bathroom back!
Posted on Aug 22, 2011
How do I fix the smell coming out of engine area. everytime it turns on it smells.
Hello friend, thank you for your inquiry!
I understand that you are receiving a smell from the engine area of your Frigidaire refrigerator. I would recommend cleaning your drain pan area, you can do that by using water and bleach in a spray bottle then spraying it into the drain pan. Also, get a vacuum attachment to help suck out any debris located in the drain pan. You can also seek consultation with a professional technician for additional assistance if needed. I hope this helps. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Theres a rotten egg smell that sems to come from air conditioning, however thi has been checked . there is a carpark above my office also customer toilets conditioning
PROBABLY not, but you might try keeping a canary in your office to be sure. The canary will die before you will.
You might take note of the breeze direction when you smell it. Periodically, walk around the area, and when you smell it again, take note of the breeze direction again. Eventually, you'll end up with a map with a bunch of lines intersecting at the source of the smell.
Some places just smell like that, especially if they're in an area where geothermal activity is common.
Jan 13, 2014 | Plumbing
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Loud noise from under the dash, ac/heater area. No cool air 97 li
If this noise is a clicking sound and is coming from the front center of the dash, then it may be the blender door motor which will require removal of the dash to replace it. It will keep the door from switching from heat to a/c. Does the odor smell like you have a freon leak in your a/c evaporator core or does it smell like a rat stuck in your heater and a/c ducts?
Aug 01, 2009 | 1997 Lincoln Town Car
Clothes come our smelling bad
Run a load empty on the hottest setting with a cup of bleach.
Then, after finished using the machine each day, leave the door open for a few hours to allow the rubber seal to dry.
Jun 30, 2009 | Zanussi FLA1001W Front Load Washer
Odor coming from front door jams after shutting car door
I have the same problem in my 2011 sonata and i finally figured out where its coming from, its inside the doors! Put your window down and then smell the top of the door where the window slides down in...its so gross....its been making me sick to my stomach!
Apr 11, 2009 | 2002 Dodge Durango
Cell phone
blinke4 - take the phone to a mobiole service center and have the phone fully service.
mcfudge - take the phone and have the lcd changed.
Apr 06, 2008 | Samsung SPH-M500 Cellular Phone
Saniflo & Saniplus& Macerator Pump  Logo
451 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
